Old 11-19-2010, 08:34 PM
william1041200's Avatar
Default questions about a 1200
Is there a hydraulic lift equipped 1200? If so, where was the pump located? My 1200 has aluminum axle tubes. When did IH start this?
Old 11-19-2010, 08:55 PM
weaverama weaverama is offline
The 1200 as well as the 1000 were gear drive quietline tractors. The 1250, 1450 and 1650 were hydrostatic driven and the 1650 had a hydraulic lift, not sure about the 1450 and 1250. Someone will be along soon to tell you about the aluminum axle tubes.
Old 11-19-2010, 09:12 PM
ljones's Avatar
ljones ljones is offline
The 1250,1450,1650 were the only Q/L's to have the optional hydro lift. I didn't think there where any alluminum trans axel parts until mtd took over in 81, mayby it was replaced then.
Old 11-19-2010, 09:20 PM
paint is flaking off the tubes, exposing corroding aluminum. I do think , but have not checked the center section is cast iron.
Old 11-19-2010, 09:23 PM
The aluminum axle tubes started partway through the QL series, probably at about the same time as they went back to internal brakes, added 1" front spindles, and used the 82 series-style steering wheel.
The 1450 and 1650 have standard hydraulic lift. It was only an option for the 1250. No IH-built tractor has an aluminum transaxle case. Only the later QLs and the 82 series have the aluminum axle tubes.
Old 11-19-2010, 09:38 PM
Talking
thank you all. Matt... thanks AGAIN. you are a super impressive wealth of information. So, would anyone out there change out the aluminum housings for iron if the option is there? I do have this option. Not really the need, at present time. but im not one to baby a tractor.
Old 11-19-2010, 09:43 PM
jbollis's Avatar
jbollis jbollis is offline
I am pretty sure that you don't need to worry breaking the aluminum tubes.
Sold everything but one.
