Old 11-26-2010, 12:21 PM
eastonct124's Avatar
eastonct124 eastonct124 is offline
Default 10" Brinly moldboard, coultier adjustment.
Plowed the new garden plot yesterday. Worked well due to everyone's tips and instructions.
One problem. I am unclear as to the coultier adjustment.
I've understand the proper swing, and the depth setting.
But, how close to the share should it be?....almost touching, 1/2", 1"?
Occasionally the sod would pinch between the share and coultier.....I tried both ways....still not sure.
Fly Fishing is not a sport...It's a way of life.
Old 11-26-2010, 05:57 PM
I viewed the manual online. All it says about the coultier is :The coultier should set at half the furrow depth".
It doesn't specify how close to the share it needs to be.
Old 11-26-2010, 06:05 PM
If I am not mistaken and I will check my manual later to double check, but the coultier only needs to make a 2 to 3 inch cut. What you will probably need to do is make a pull with the plow with the tractor tires down in a previous furrow to be at the correct angle. Stop your tractor, leaving the plow down and visually see and measure how deep the coultier is cutting. If it is too much raise it, if not enough lower it. That will also be a good time to make sure the plow is pulling straight and cutting straight. If not you can make adjustments.
Old 11-26-2010, 06:44 PM
I understand that. And it is set at the correct depth. But, I can move the whole assembly (when loose) like a pendullum from 5:00 to 7:00, and this changes the distance between it and the share.
My question is: "Should it almost touch the share, or should I be able to wrap my hand around it and the share?".
Old 11-26-2010, 07:59 PM
Ahh.. Ok I didn't understand the question completely. The coultier should stop just shy if moldboard. I think mine is about a 1/4 away when at the closest point. Sorry about that . It shouldn't break the plane of the moldboard edge.
Old 11-26-2010, 08:10 PM
Great! Thanks.
I thought having it close seems best, so when it cuts the sod, the sod just slides from the coultier to the share, and rolls out.
When there is too much gap, it gets caught between the wheel and the share.
Is this the correct line of thought?
Old 11-26-2010, 10:16 PM
You got it
