Old 11-26-2010, 01:59 PM
BruceB BruceB is offline
Default 102 Snow blade
Hey guys
It's me again, so I got the new return springs on the blade, but now I am having problems mounting it to my 102. I am not sure if I am missing a bracket, or if I have the wrong under carriage. I sure could use some help.
Thanks
Old 11-26-2010, 02:40 PM
Originally Posted by BruceB View Post
Hey guys
Thanks
A picture would really help.
Old 11-26-2010, 03:32 PM
Sminkey
Guest
Posts: n/a
Default Hey Bruce!
Like Methos said, pics are very helpful, but here is a link to the install manual and hopefully that help's
http://ccmanuals.info/pdf/Front%2042...l%20Manual.pdf
Old 11-26-2010, 04:03 PM
hilltop's Avatar
hilltop hilltop is offline
Sminkey,
Thanks for the pdf post!
I missed it in the manual library and I've been trying to scrabble up enough info to fab up a blade and mount for my 104.
Old 11-26-2010, 07:57 PM
Guys
Thanks I have the bolt on type. I took some pictures, however I am having problems uploading them to the internet. I tried with the bolt on and it was to narrow to fit on the outside of the frame on my 102. And it seems that the lifting bracket on the rockshaft is striking the subframe of the plow. I hope I can get it to work.
Thanks guys
Dave
(Bruce's son)
Old 11-26-2010, 08:32 PM
There are some extension brackets you are probably missing. Unfortunately I don't have a picture.
Old 11-26-2010, 09:15 PM
these are on my 100.
I was told that if you have the mule drive on without the undercarriage or pulleys you do not need those.
Old 11-27-2010, 01:55 AM
Hey guys
The pic that darkminion posted is the same type of sub frame. I guess I need to make those extensions up. Looks like the extensions are about 3 or 4 inches. I will have to Fab some up. I did try by taking the pulley off the mule drive and it is keeping the blade about 1 inch off the ground, and also the lift rod may not be the right size now.
So if I could get some dimensions of the extensions and the overall length on the lift rod I would appreciate it.
Thanks All
Dave
Bruce's son
