I have a couple pictures of a kohler engine. They are not the best, but by looking at the head I am thinking it may be a 16hp. Can you guys help me out alittle. I might be wanting to purchase this, if it is. I can't get any other pictures at the moment. So do you guys think it looks like 16hp ?
Sold everything but one. 1211-snow pusher, cab ,54 inch plow, loaded tires (all 4) Gilson wheel weights, X-trac fronts- soon to have power steering and dual hydraulics |
I think I can see 10 head bolts on there, which would mean it's a 16 hp. That's an interesting generator it's connected to.
I was pretty sure it was. The head bolt holding the tank on is throwing me of though. But if it were a 10-12-14 the head bolt on that end would be between the 2 that are there, I think. The 10-12-14 only have one bolt on that side side of the jug and it is in the center. If i am thinking right.
it must be a 16. Now I just need to make sure it is a narrow base block. The guy says it is from a service truck, and they used it to jump start things. I am guessing bigger trucks and equipment.
I went and looked at it. I do believe it is a 16hp, but it is a wide base block. It is on epay, listed under Kohler engine. If anyone else can use it, the starting bid is $100.
