Old 12-05-2010, 09:21 AM
dads70's Avatar
dads70 dads70 is offline
Default remove a rusty muffler from engine?
ok guys, is there an "easy" way to remove a exhaust pipe from the block of a k-181 thats rusty? they used the bolts to attach it to the block and they made some kind of homade exhaust thing with the round muffler thats pretty rusty on it.
im looking to remove it and use the threaded pipe with a new muffler, thought of "SOAKING IT IN P.B. BLASTER" THEN use a pipe wrench, also thought of heating the bolts up with a propane torch and try slowly removing them any thoughts?
thinking about using a "stack" like allen did on his 100 i know some think they will crack but im looking at making a support from the mule bolts as well as frame grill 100's are cool but im pullin for the lil guys 70
Old 12-05-2010, 11:46 AM
You are spot on for what to try. Spray with PB Blaster for a "few" days and then try to break them loose. If no luck apply liberal amounts of heat and try. They will eventually come out.
