Old 12-12-2010, 04:10 AM
animal animal is offline
Default Another Creeper issue
Hi, just finished installing my creeper but the handle I got from CCspecialties for my 126 appears to be too short. I sent them an email and for the life of me I can't figure out how I installed it wrong. How do I fix this?
Cody
126, QA42, 48 in deck
Old 12-12-2010, 07:29 AM
Sminkey
Guest
Posts: n/a
Looks like you got a creeper with a Narrow Frame handle instead of the one for a wide frame, you'll need an extension which cc or other sponsors here have. I'm no expert and if I'm wrong someone will set me straight:biggrin2.gif:
Old 12-12-2010, 09:34 AM
The creeper is correct because the 126 is still a NF, but all of the high-tunnel NF tractors (like the 126) need the handle extension.
Old 12-12-2010, 10:53 AM
nickvanorman
Guest
Posts: n/a
i had this EXACT same problem with mine. was gonna ask about it but you beat me to it. ill have to find an extension. does it also extend the breather too?
Old 12-12-2010, 11:07 AM
Yes, you also need a couple of 1/8" NPT fittings to extend the breather, too.
Old 12-12-2010, 04:59 PM
Ok, stupid question why do I have to extend the breather?
Cody
Old 12-12-2010, 05:29 PM
So when it pukes all the oil out of the breather you can more easily remove it to add more Hytran. I suppose you could also use a piece of clear flexible tubing and a funnel. It may also keep it from blowing too much overboard if it is extended.
