Old 12-14-2010, 10:22 PM
squatch squatch is offline
Default Tire fluid IV.
Made myself a little IV bottle to fill the tires on my 1872 with windshield washer fluid.
I took the cap off a fluid jug and drilled a hole in it to mount a screw in tire valve.
Then removed the valve core and added a peice of 5/16" fuel line and a hose clamp.
Cut a small hole in the bottom(top) to fill the jug along with a wire bail and suspended it from my engine hoist.
Remove the valve core from the tractor tire and install the fuel line(WWF drip) and add a hose clamp. Make sure the valve stays at the 12 o'clock position. After the tire is full to the valve re inflate to 12 psi.
I then added 1/2 jug of fluid to the IV and stood on the tire to deflate it as much as possible. Lot's of WHOOSH and bubbles in the jug.
When I stepped off the tire it started to re-inflate itself drawing in the fluid. I helped this process along by placing a floor jack under the axle near the wheel and jacking it up in stages taking the tractor weight off the tire.
This is one cycle. It took several cycles of weighting and un-weighting to fill the tires. Don't let the bottle go dry. This isn't the fastest way to do this probably but it is cheap, simple, effective, mess free.
I used 3 gallons in each 18x8.50x8 front tire and 8 gallons in each 26x12x12 rear tire. I still need to add fluid to my to spare rear wheels with turfs for the tire chains. I'm also running my 50 lbs each rear wheel weights. This should be a big improvement in both stability and traction. I sure feels like it so far.
Old 12-14-2010, 10:41 PM
Yamaguy's Avatar
Yamaguy Yamaguy is offline
Thats the best way to do it IMHO!!
Old 12-15-2010, 02:58 AM
That's awesome!
Old 12-16-2010, 05:54 AM
nikster's Avatar
nikster nikster is offline
I have the standard weights on mine, I guess adding another 25lbs. or so
per tire can't hurt? I've got a flat driveway & flat yard so with the chains & weights
I do O.K..
Great idea doctor.
Nik,
Old 12-16-2010, 10:40 AM
As big as they are the Supers are kind of rear light. Doesn't take much to spin tires even with weights and chains. Add a couple of hundred pounds of snowblower on a lever in front of the front axle and that lightens the rear even more. A little addition weight goes a long ways. Spnning the chains on pavement on one of these can make some nasty marks in the pavement. I've got hilly property and with the steel cab on the weight also goes a long way towards lowering the center of gravity as well.
Old 12-16-2010, 09:45 PM
Mountain Heritage's Avatar
Nice....great idea. This must be a fun tractor to use in the snow..bet you can't wait to play...errrr I mean work with it! :biggrin2.gif:
Mike
Ontario, Canada
Now everyone wants a Cub!
Beware of the Wife
Old 12-16-2010, 11:13 PM
ihnick's Avatar
ihnick ihnick is offline
how long does it take to fill a tire?
Nick.
Old 12-17-2010, 01:57 AM
I can't be exact but it took me the better part of an afternoon to get them all done.
MH, We got a little over an inch of snow today on well frozen ground and roads. It stuck, packed to ice and was slick as (you know). I went out this evening for a traction test. Running my new v61 and AGs filled. I simply could not spin a tire. Neither forward or reverse or if i stopped quickly. The extra weight really planted the tires. These pics are from last year of the hill at the beginning of our road. I spun all the way up in my FWD car tonight coming home from work. I could NOT MAKE the tractor spin! No chains or plow on yet. I could have shredded the old turfs here without the extra weight.
Old 12-17-2010, 06:28 AM
Tim S. Tim S. is offline
Also on filling the tires if you have one of those small plastic landscape ponds (where the the turtle or whatever spits the water out of it's mouth) the pump out of it works great too.
Old 12-17-2010, 08:50 PM
Now that's a nice hill to have to climb.... Last time I tackled a hill like that with my Chevy....ended up coming back down it side ways with the wife beating my right arm yelling and the kids...well I think they were scared...s !
We laugh about it now...but I think I traumatized the rest of the family. Note to self..."Change tires before trying to climb hill covered in ice, especially when they are near bald!"
:biggrin2.gif:
Still can't wait to see them action shots
Mike
Ontario, Canada
Beware of the Wife
