Old 12-20-2010, 04:35 AM
rwire125 rwire125 is offline
Default H42 speed up pulley
I picked up an H42 Haban thrower that needs a drive pulley not knowing the correct size for sure, was thinking I could use a smaller pulley to up the RPM's and throw the snow better. could someone tell me what size the org. pully is
Old 12-22-2010, 06:53 PM
what the heck, I know there are more out there. if I new the org Dia. of the drive pully I could base my new size off. Right now i have a 31/2 pully in mind
Old 12-22-2010, 06:57 PM
I don't have a H42 and only have knowledge of the original part number. BUT....IIRC seems that I read you could downsize to 3".
Old 12-22-2010, 07:04 PM
Keep in mind all of the H42 parts are NLA...I would not spin it faster and speed up the wear on everything. It should throw snow plenty far stock...do you have the chute coated with slip plate?
The thrower has to be kept full to throw snow the furthest. You will have to vary the groundspeed accordingly. When the thrower is full, the engine will be just tugging on the governor a bit.
Old 12-23-2010, 04:08 AM
the problem is it does not have a pully on it so i dont know what the stock size is?
Old 12-23-2010, 05:50 AM
IIRC, the OEM part was 3.5"
There must be some H42 or H48 owners out there that could measure one up...
Old 12-23-2010, 02:31 PM
cubby cubby is offline
HERE HOPE THIS HELPS http://cubfaq.com/thrower.html
Old 12-23-2010, 03:53 PM
Cubby:
That reference is for the IH QA Series snowthrowers NOT for the Habans
Old 12-23-2010, 07:06 PM
I saw that, thats whare I got the idea for the 31/2 pully but still dont know what the org size was to start with
