Old 12-25-2010, 05:31 PM
jwk49 jwk49 is offline
Default 1811
I picked up this 1811 Cadet a few months ago and started to restore it, but then the weather put a hold on the project, It needed quit a bit of work but is starting to look like it should. New Paint, Decals, overhaul Snowblower gear box, add weights and chains, Tune up all new filters and fluids, brake adjustment.
I have had all international cub cadets for the last 40 years and this is taking a while to get use to, controls on the opposite side is a real challange. But the Snow blower and starter systems are much better. I still have my 169 but wanted to try a newer one so I got this 1811.
I have attached a few pics of the project.
Jim
Old 12-26-2010, 12:17 AM
Great looking 1811, jwk49!
Old 12-26-2010, 12:39 AM
Mooner's Avatar
Mooner Mooner is offline
JWK, that is a sweet looking 1811. Yikes, how much snow did you get there?
Any photos of your 169?
Old 12-26-2010, 03:21 PM
Default snow
I am outside Buffalo and about 3 weeks ago we had about 20" but not a lot since then, some towns near my office got 3' that same 2 days.
I have my 169 put away for the winter I will see if I can find any pics. if that is your 149 I have to say mine is not as Clean as your 149, Nice Looking Cadets
Jim
Old 12-26-2010, 03:42 PM
Mooner's Avatar
jwk49, you can see my Cubs in my album. Very little to do on them. I lucked out!
Old 12-28-2010, 05:31 PM
Carl_NH Carl_NH is offline
Jim,
Thats a very clean 1811 you have looking like a new one! I bet you have quite a few hours into it now. Just curious how do you attach the rear weight at the bottom?
I have an 1811 which i removed the 3PTH due to the hitch being attached to the AL tranny always causing leaks, and replaced with the CC rear hitch plate attached to the frame for towing. Now no more tranny/hitch induced leaks.
Old 12-28-2010, 09:21 PM
MrGitrdone41's Avatar
Nice looking 1811! I have a 1812. I have 80 pounds on the rear and plows like a dozer!
Old 12-28-2010, 10:08 PM
Default rear weight
I have a 8" x 8" steel plate bolted to the tow hitch and the concrete weight sets on top, I put an eyebolt into the concrete when I poured it and connected it to the rear sheetmetal with a 5" turnbuckle to adjust it,
It sounds more difficult than it was, I have done this for my last 3 tractors, it really does help a lot.
The internationals with the snow throwers are lighter than the 1811 with the blower, but either one works fine.
I also have wheel weights of a Bolens that are about 80# ea, maybe a little overkill but it works.
Old 12-29-2010, 12:59 AM
You may want to add some more support for that concrete block. There is a tongue weight limit on the aluminum rears that is not very high. I'm sure you've greatly exceeded it with that thing. That should be braced to something structural like the frame.
Old 12-29-2010, 07:01 AM
Jim,
Thanks for the reply on your mounting and I agree with Matt on the support of the block - it should be on the frame.
I learned the hard way towing a trac vac with AL axle rear plate pulled the bolts from the tranny and was a devil to keep tight and leak free so I got the rear hitch plate PN 703-1943A - RF Houtz has one for $47 cheap insurance and will protect your transaxle as it connects to the frame.
I also had 3PTH that was no longer needed so I removed that and installed the hitch plate - no more issues with the tranny.
