Hello, is it ok to run chains on Tru Powers? My 23x10.5x12 were spinning all around before and got stuck !!! haha i guess my extra weight (I am 265lbs) is just not enough. The 127 did work pretty well though.
1969 Cub Cadet 127 Cub Cadet HDS 2155 w/ bagger #2 IH cart 48" deck 42" Front Blade Brinly Sleeve Hitch and Brinly Plow IH wheel weights
JaysNJcub127...
Try adding some more weight to your 127... How much snow do you have on the ground? I was going out tonight but it seems fruitless. |
snow very packed down and slick there is like 3 ft haha
If there is anything slick between the tire and the ground, you're not going anywhere without chains period! I don't care how much you weight it down.
Ag's and chains may be alright, but turfs and chains is the way to go. 2 link chains won't beat you to death either.
So turfs? ag's? with chains? whats the way to go. What kind of chains? 2 link 4 link?
Jason,
I run 2 link with turfs on the 125 with 150lbs. of weight.Same setup I use when pulling a plow in the spring.The two link spacing allows for a smoother ride.But if you don't want to scratch up your driveway,they have rubber chains you put on.Just like the rubber wheels they use on the elevated trains in Chicago to make them quieter...If you believe that,There is a bridge in Brooklyn I could sell you... |
My drive is blacktop, will not scratch. i have like 4ft drifts by my house.
I have 4 link V bars on my 1450 with 70# per wheel + my 214#. I do a lot of spinning pushing the 54" blade. I'm changing out the 54 for a 42 next storm.
Papaw 1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift.
I doubt you have anywhere near enough weight. 300 lbs. seems to be the magic number for mine.
i am running a 123 with turf tires-8.5'' wide- 4 link chains, i am 150lbs with an extra 120 on the back. 42'' thrower and i really do not have any trouble going through a foot or two of snow. sometimes if i am faced down hill with the thrower off the ground and tryin to back up i spin a little so i am sure a little more weight would solve this problem. of course i would rather have ag tires with two link chains and about 50 to 70lbs more weight on the back.
