Old 12-29-2010, 11:05 PM
animal animal is offline
Question Belts
Ok so I destroyed my cw-36 the other day when the input pulley came off. So I drive up to PA and scored a nice QA-42 off a 147. It came with a 3.5" speed up pulley that is for a 1/2" belt. Now here is the weird part it was on a PTO that measured the same as mine which I thought was a 3v/vx section because that is what the IH-487043-r1 belt is. My 48" deck belt is a carlisle power wedge 3VX750 that came with the 126. Is there a different PTO that is used with a speed up pulley? Can I use it with the Goodyear Matchmaker A26 belt it came with? The guy I bought it from had gotten the 147 set up this way from the long time 2nd owner. He said that the 2ndPO had been using it this way for years of PA winters.
Cody
126, QA42, 48 in deck
Old 12-30-2010, 10:44 AM
First, what model of tractor are you mounting it on?
The speed-up pulley is not a factory modification, and the clutch does not change. All of the mechanical PTOs are the same diameter.
I have always run 1/2" belts on my snowthrower tractors, as the aftermarket pulley that matches the original one is a 1/2". Since you no longer have the OEM pulley on it, you'll have to measure for the correct size belt. And at any rate, the only way anyone is going to know if the belt your thrower came with is actually going to work or not would be for you to put it on and try it. We have no idea what size pulley you now have on the snowthrower, so you'll have to measure it and buy the appropriate belt. A 3/8" belt will bottom out in a 1/2" pulley and not work.
Also, if the pulley is die cast aluminum, don't use it. You need a stamped steel or cast iron pulley.
Old 12-30-2010, 01:02 PM
Guess I was clear as mud, so here it goes. The qa42 with a 3.5" dia X 1/2" speed up pulley is going on my 126, it came off a 147. My big question is the PTO designed to accept belts bigger than 3v/vx section? Sorry for the confussion
Cody
Old 12-31-2010, 07:25 AM
I would highly suggest that you ONLY use a Cast Iron Pulley. I have seen posts, where the aluminum, pot metal, stamped steel, and any other cocktail of metals just don't hold up. Save yourself the money & grief and use Cast Iron.
