Old 01-01-2011, 05:43 PM
jbbailey jbbailey is offline
Default 104 Engine Question
Hello to every one. I am fairly new to Cub Cadets. I noticed today that my 104 has a blown head gasket. It smokes a llittle through the exhaust and the side cover over the valves. My question is, could the smoke be from the head gasket or are there other things I should do to the engine while the head is off (rings, valves, etc) or just "machine" the head and replace the gasket or more in depth work? Thanks for the help.
Jay
Old 01-02-2011, 03:00 AM
johncub7172's Avatar
Default This should help.....
Tec. Library pg.2 Kohler Head Gasket Replacement by Matt G.
Old 01-02-2011, 02:16 PM
Default Thanks,
Thanks, for the info. I read through that paper, good info I will follow it. Should I consider doing any other work to the motor while it is down? I got the tractor late in the summer and don't really know much about the engine. I did mow a couple of times with it, it smoked a little and used a little oil.
Jay
