Just wondering what your guys preference is? For snow and mowing duty I like a hydro. I haven't had a chance to do much other stuff with a gear drive yet
Nick. ![]() Cub cadets 100, 125, 86, 108, 109, 128, 129, 129, 149, 149, 169, 1450, 1650 and a handfull of parts tractors. #40 box blade, ih back blade, rear ih rock rake, #2 cart, windbreaker soft cabs, windbreaker hard cab, cozy cab, kwikway loader , wards corn planter, brinly plows, culitvator, rear blade, disc and the usual decks, snowblowers and 2 tillers |
I feel the same.
Dale 147-Restored___________________882 Diesel Hydro lift (not installed)___________44" Deck 48" Deck_______________________QA-42a/b Snowthrower Rear lift ________________________XMW cat-0 rear lift Model 2 tiller____________________12" cat-0 Brinly plow |
I have the 128 gear drive, but all the other cubs I have owned and am currently getting are hydro, if that says anything
. Just so much easier to move the handle up and down than to stop reach down and change gears and so forth.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
I like both, but for heavier duty I like the Hydros better... I use my CCO for hauling and light duty stuffs.
Jay N. Eau Claire, WI RED 82 Series... The BEST cure for Yellow fever!
This is the age old question, like Bill said if you have many things to mow around a hydro is easiest, but if you have a lot of hills and humps or long straight-aways with no other obstacles, a gear drive is better by far.
For moving snow, thrower or blade... Hydro, HANDS DOWN! For those of you who's wives think that you only need one "lawnmower" the afore mentioned are some of your best arguments for multiple Cubs. This small list should net you at least 4 Cubs!
Well for me I perfer a gear drive for pulling a moldboard plow and working out in the woods hauling fire wood logs and mowing large open areas.
I perfer a hydro for snow duty, tilling, and mowing confined areas. I find it best to own at least 1 of each and have each in top running condition and haveing a spare cub just incase. Oh !! and a few parts tractors laying around comes in handy when you need that busted part like yesterday. |
I think gear is stronger and will last a heck of a long time where your hydro. is going to need this and that. The most of what I see pullers using are gear. But I have a IHCC 123 that I want to get going. Sure, already I can say how much I'am going to like my hydro.! Having had only gear and no hydro.! I want a HYDRO.!!!
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
I prefer pulling a plow and pushing snow with a gear drive, reason being you don't have to listen to the noisy hydro and mess with the hydro lever all the time. However, at plow days, a gear drive is a pain because you have to keep stopping all the time to let the hydro tractors get further ahead again:biggrin2.gif:
i prefer the gear driven tractors. because (on most of the tractors ive run with Hydro) the hydro lever is on the dash. which means you need 3 hands to 1. work the implement lever 2. steer the wheel and 3. run the hydro lever. gear is nice since you have the clutch you can use your foot and have complete control. unless you have a hydro with foot pedals.
ive always been true to the argument that Gear drive is better for moldboard plowing than a Hydro. as, with a hydro, you lose horsepower to the wheels. while with gear drive, you have it all. ive run both in plowing. gear drive is superior. |
