Old 01-06-2011, 02:09 PM
drhntrrmw's Avatar
drhntrrmw drhntrrmw is offline
Default 122 will start but won't take throttle...
I recently rebuild the carburator on my 122 and after reinstalling it and putting in a new battery, it started right up. I only ran it for a short while gave it full throttle a couple of times.
It is now very finicky with the throttle and if you try to give it more throttle it shakes the tractor profusely.
any thoughts???
Rob
Old 01-06-2011, 02:15 PM
Could be that the Carb is set too lean.
Old 01-06-2011, 02:31 PM
drhntrrmw's Avatar
I set the high-speed at two turns out and the idle at a turn and a half out. It seemed to be to rich to me and I was attempting to lean it out.
You may be correct with your to lean comment. I thought is was to rich because of the gassey exhaust. This is my first time tuning a carb and it isn't as simple as I thought it might be.
Old 01-06-2011, 04:01 PM
As found in the Service Manual....
Old 01-06-2011, 05:15 PM
gadgetman gadgetman is offline
Any progress?
One thing that I've done, had a similar situation where it started really hard, wouldn't accellerate off idle, thought I had carb issues.... turned out I had knocked the condensor wire from the coil.
Hooked it back up, runs like a champ!
Probably not your problem, but its something that I will not overlook again!
Old 01-06-2011, 05:29 PM
powerpooch's Avatar
powerpooch powerpooch is offline
I would second checking the condenser. The bolt holding mine vibrated lose while blowing snow, only could ideal the engine and anything else would either stale or vibrate horribly.
Old 01-07-2011, 07:37 AM
drhntrrmw's Avatar
Could the condensor be bad??
I thought it was the carb as well and rebuilt it but it was pretty clean when I took it appart. Sounds very similar to your situation.
Old 01-10-2011, 07:39 AM
drhntrrmw's Avatar
I changed the settings to the carb and that has helped but it still doesn't run great. I think it still needs a good precise adjusting.
I may change out the condensor as well.
