Old 01-12-2011, 11:36 PM
MrGitrdone41's Avatar
Default How to put on decals
What is the easiest way to put on decals on a wide frame? I heard to use Windex on them to move them? I don't want to mess them up.
Old 01-13-2011, 12:57 AM
dieseldan123's Avatar
What model wide frame is it? and do you have the old ones off/ have a picture refference? Quiet lines are a little harder to do. If its a later model wide frame they arent as tricky. Windex helps you move them before the final stick and use a plastic scraper or credit card and gently work the bubbles (and Windex) out. Also use masking tape to help hold them in place. This is how i learned to do decals.
1967 IH Cub Cadet 123
1978 IH Cub Cadet 1650
19?? IH Cub Cadet 682
Old 01-13-2011, 04:26 PM
It is a 128. Thanks for the tips
Old 01-14-2011, 02:33 PM
Mlamar Mlamar is offline
Default Just a little goes a long way
Don't use too much of the Windex, a little is all it takes. A mist instead of a dripping wet surface. Also warm soapy water is good. Wash the surface the decal will be applied to with soap and water, especially if it's new paint. Be sure that the decal has it's protective cover on the shiny side (surface facing up that you'll see when done) to protect it from scratches when you squeegee as you remove the air bubbles. I have applied decals to models Original up to the 1650 and all have turned out fine. Just take it slow. Some of the covering may need to be trimmed before you apply the decal. If so stay close to the edge but be sure not to cut into the decal. Squeegee the moisture away and let the decal alone for awhile (allows moisture to dissipate) Take your time peeling it off so you don't peel the decal off as you go. And most of all HAVE FUN:biggrin2.gif:
Old 01-14-2011, 09:18 PM
well i got the decals on but i didn't have Wendex but i got them on and they turned out great thinks for your help.
Old 01-14-2011, 11:51 PM
Anytime, and it sounds like you Got-er-did, MrGitrdone! hope to see some pics of it soon. I did my decals "dry" but still turned out great. realy made my 123 stand out!
Old 02-27-2011, 09:22 PM
GoatDriver's Avatar
GoatDriver GoatDriver is offline
Just a note fellas...I owned and operated a sign and decal business for over 10 years and i think you guys should know..Do Not Use Windex to apply your decals..it is bad for the adhesive of the decal.
Instead, use a solution of 1 part water, 2 parts rubbing alcohol, and 1 or 2 drops of dish detergent...after thoroughly cleaning the area to apply the decal to, then lightly spray the solution on the area and the adhesive side of your decal and apply your decal..... once you have your decal in place, it will require a good "squeegeeing" to squeeze out the solution and let it dry for several minutes before removing the cover mask. Have a good 'un!!
Old 07-01-2012, 01:28 PM
bvillecadet's Avatar
bvillecadet bvillecadet is offline
[I] have to agree. I've been a sign maker for an awefully long time and never used windex. get a small spray bottle fill with water and add about three drops of palmolive (the green one) spray area and adhesive side of decal with solution the water helps to slide them for proper placement and then sqeegee the bubbles out. if they've been taped properly just use the top of decal for straight edge. Work in the shade on a nice warm day if possible.
1970 Cub Cadet 107 currently being restored.
Old 07-01-2012, 02:19 PM
bocephus1991's Avatar
When I did my 1200 I didn't use anything. I took my time and got them where I wanted them and worked it from the middle of the decal out. I have a couple tiny bubbles in one spot on the tower.
Brian
Old 07-01-2012, 02:33 PM
nikster's Avatar
nikster nikster is offline
I used water with a drop or 2 of dish soap, & have used plain water & windex,
Gives ya time to slide around & position & easier to get out the bubbles when ya finish of with a credit card.
Nik,
