Old 01-23-2011, 10:28 PM
brucer95's Avatar
brucer95 brucer95 is offline
Default Easy exhaust brace
Here are a couple pics of a cheap and easy brace I made after reading some of the threads on here. Its a peice of 1/4 x 2 flat iron ran across two head studs , a muffler clamp ( I will get the right size ,t just didn't want to go to store) and a 1/4 inch bolt. I drilled a hole in the clamp ground the head of the bolt down to fit up in the clamp, and ran the bolt up to the brace. I think it will get the job done.
129 Plower; 72 pile;122 daily driver, 2-42inch blades 42 inch deck- 06 GMC 1500 4wd- 1964 farmall 706
Old 01-23-2011, 10:32 PM
Looks like it will do the job. Way to use the old noodle
Old 01-28-2011, 03:56 PM
william1041200's Avatar
I like it! And it looks great yellow too
Old 01-28-2011, 04:27 PM
I like noodles! Ramon noddles! Opps wrong topic!
Looks good to me!
Old 01-28-2011, 05:55 PM
cubs-n-bxrs's Avatar
Nice idea do you have any pics of that set up with the hood down and what model tractor is this on? Just built a custom made glass pack muffler/stack for one of my tractors and it is considerably heavier than stock and will require some brace work.
Old 01-29-2011, 10:58 PM
young enthusiest's Avatar
The tractor is a 1x8/9. I can tell that from the pto, QA lever, and cast grille. I took a quick look at my 1650, and by drilling a few holes in the tin on top of the head and adding 2 studs, this could be done on an AQS engine too. This is a very simple design, straightforward and tidy. I like it!
Brucer95 you could probably make those brackets and sell them...
