Old 01-24-2011, 08:38 PM
Duster72 Duster72 is offline
Default Help
Got the 124 running . Now need help putting a snow blade on it. The snow blade I have is off a wheel horse what is the best way to put it on.
Old 01-24-2011, 09:00 PM
jbollis's Avatar
jbollis jbollis is offline
The best way would be to sell it, then buy the correct one for your cub. It will be cheaper in the end, trust me.
Sold everything but one.
Old 01-25-2011, 07:54 PM
Ray Ray is offline
Try posting some pictures of the blade and mounting bracket and see if some of our fabricators can help you. But in the end jbollis will more than likely be right.
Old 01-29-2011, 01:50 PM
nuzzget nuzzget is offline
Yea post some photos i successfully installed a snow thrower on my 127 and the snow thrower is not international or even for cubs.
Old 01-29-2011, 03:15 PM
The WH tractors have enough of a following that you could sell the blade and use the $$$ to get the correct blade for your CC. I once modified a blade to fit a Cub, and I'll never do it again. It wasn't worth the trouble. The correct ones can be found if you have patience and look around a bit.
Old 01-30-2011, 12:02 PM
nickvanorman
Guest
Posts: n/a
modifying blades isn't all that bad. sometimes its cheaper than buying a CC blade. ive modified a ton of snow plows to fit tractors they werent supposed to.
