Old 01-27-2011, 06:44 PM
cubcadet109 cubcadet109 is offline
Default Won't run right
My 109 won't run right, I've been doing a lot of plowing snow, and all the sudden tonight, it wont run right. I adjusted the carb, cleaned the plug, and checked the point gap, still not fixed. Anyone thinking water in the gas? I'm just going pull the carb and clean it, because its still snowing here. any other ideas?
Old 01-27-2011, 07:34 PM
Please elaborate on 'won't run right'...that could mean a hundred different things. Won't stay running? Runs rough? etc. We could list a bunch of stuff for you to check, but help us narrow it down a bit.
Old 01-27-2011, 08:20 PM
It idles, but when you pickup rpms, it bogs& almost dies. Dirty main jet?
Old 01-27-2011, 08:36 PM
mharrison's Avatar
sounds like it's in the carb, probably main jet
Cub Cadet 149
IH Lawnboy 3321
IH Cub Cadet 782 w/ dual hydraulics-M18 powered
1977 Wheel Horse C-160 8spd w/ 48" deck, dumpcart
Old 01-30-2011, 07:29 AM
OK I've cleaned the carb, put water remover in the gas, cleaned the plug, set the points, and it still wont run right. Ive adjusted the carb to the specs and adjusted both ways from there when it is warm. Should i get a new spark plug? I'm thinking it's somewhere in the ignition system. coil, condenser, i don't know. I'll look at it after church.
Old 01-30-2011, 08:08 AM
rmunro's Avatar
rmunro rmunro is offline
If it starts right up, no problem, I don't think you have ignition problems.
Is the governor working?? I would check that 1st.
Next I would check the fuel flow. Perhaps partially pluuged line, or tank outlet, not providing enough fuel.
I assume it isn't blowing black smoke??
Roger,,109,1450,1210
Some Days all You Can Do Is Hang On!!!
Old 01-30-2011, 08:11 AM
Check the condenser.
Old 01-30-2011, 12:22 PM
I think there is enough fuel flow. It backfires through the exaust so it is probally to lean right, because if it is ignition it would be through the carb. Am i correct there? thats what ive always thought. I'll pull the carb again and go through it extra good, then look at ignition stuff. How do you check the condensor? Yes, i do beleive the govenor is working. its got to be something olbious i guess if i haven't found it yet. its wierd that it happened suddenly. usually the carb just happens over time.
Old 01-30-2011, 04:18 PM
Before you take the carb off again, start the tractor and pull the choke a bit when it stumbles. If it clears up, you have a fuel problem. If it doesn't, it is probably something else. If it's running lean, adjust the main jet on the carb so that it runs richer.
Old 01-30-2011, 06:21 PM
Adjust the carb....may have to go beyond specs--just listen to the engine. If it has backfired several times or hard, then I would go ahead and replace the plug anyway as a precaution!!
