Old 02-03-2011, 09:01 PM
cef2lion cef2lion is offline
Default 149 K321 block issue
I got to looking at the K321 from the 149 I was going to restore. After pulling the pan I saw that the connecting rod had broken close to the crank. I pushed the piston up and saw that the cylinder sleeve was broken off on one side right flush to the block. Guessing the block is done. Could be unseen damage as well. The piston was was marked 10 over. The connecting rod appeared STD. I did some searching today on rod breaks and saw this kind of damage. When I got home sure enough this one suffered the same.
Project will have to sit now till I figure if and how to proceed.
Craig
'67 125
'72 149
'61 IH Cub LoBoy
Old 02-03-2011, 09:51 PM
centaurdave centaurdave is offline
Default 149 k321 block
this is not the end. send pictures. there are several kolher knowlagable people on this forum. so, pictures please.
Old 02-03-2011, 10:01 PM
Merk Merk is offline
You may be able to put a sleeve in your block.
We need some pictures..
Old 02-04-2011, 01:25 PM
Dave R Dave R is offline
Default Little advice from here
Wish I had something to offer positive, but I don't know what to advise about the cylinder issue.
I can tell you this much, when I got into my K321 the balance gears were all over the place, but still on the shafts. Both wobbled, didn't line up and were loose. So in rebuilding I plan to do as a lot of guys have suggested, leave the balance gears on the table when it come time to reassemble the engine.
I can't see why they didn't destroy teeth or possibly come apart the way the both wobbled.
I'll bet one thing, when your rod broke and it hit the bottom of the cylinder wall there was a lot of racket before the silence.
Dave
Old 02-06-2011, 12:48 PM
I pulled the crank to get a better look at the block. Flywheel was extremely hard to get off. Gave up and left puller on over night. Gave the end of the puller a slight tap and off it popped.
The crank journal looks ok. The cam appears ok. ACR springs and operation seemed ok. Governor gear looked ok but would have replaced anyway. I don't see any other case damage. Before pulling the crank I checked the cam and balance gear timing just out of curiosity. Cam timing seemed correct but the balance gears didn't. I know most say to pull the balance gears anyway. Piston was marked 10 over.
As as option I'm going to start looking for a block or engine. I can keep this one for parts for now.
'67 125
'72 149
'61 IH Cub LoBoy
Old 02-11-2011, 03:43 PM
I found a K321 short block a short distance away at very good price. Turns out we had a mutual friend. Appears to be in good shape and it had a STD piston in it. Going to have it checked out and prepped along with my crank and then gather up what I need to complete a rebuild. Picked up a few extras as well. SG and 149 headlight panel.
'67 125
'72 149
'61 IH Cub LoBoy
