Old 02-12-2011, 06:46 PM
Dave R Dave R is offline
Default More troubles with cylinder wall now...
I have the crank out and now I see a chunk broken out of the bottom of the cylinder wall. Its about 1/2 inch deep up the side of the wall. So where do I go from here. I see a small nick out of the opposite side of the wall. Photos attached.
Can or will a machine shop rebore the cylinder or is it worth even taking to them?
Thanks for the suggestions.
Dave
Old 02-12-2011, 06:47 PM
Yep, Motion Industries or NAPA should be able to cross it to something they have.
Old 02-12-2011, 06:50 PM
This is just a quick question and I am sure you have done this, but you did loosen the lock ring that is behind the bearing??
Old 02-12-2011, 07:17 PM
Default K321 bearing
NOPE...tell me more..
Dave
Old 02-12-2011, 07:30 PM
steve59's Avatar
steve59 steve59 is offline
Dave, The bearing has a lock ring behind it. The ring has an allen head screw with a lock nut on it and a notch in it. Once you loosen the set screw and lock nut, tap the ring counter clockwise (I believe) with a punch in the notch until it's loose and the bearing will come right off with a puller.
Old 02-12-2011, 08:32 PM
Default Thanks Steve59
Thanks, its a wonder I hadn't beat the crankshaft into trying to get it off.
Never hurts to ask.
Dave
Old 02-12-2011, 08:48 PM
Thanks to Steve for having the reply, I have been in town with the daughter. Sorry for the slow response on my end...
Old 02-13-2011, 12:33 PM
Default Loosened the collar
I loosened the collar and it still won't budge. Guess I'll break another puller.
Old 02-13-2011, 09:19 PM
108cubber 108cubber is offline
Do you have an angle grinder with a cut-off wheel on it. If so, you can cut the outside race off, get bearings out of the way and cut most of the way thru the inner race. Put chisel in cut line and smack with hammer, hopefully breaking race in two. Should come off easy then.
KennyP
Old 02-13-2011, 09:30 PM
steve59's Avatar
Dave, Do you have this type of puller? It's made to pull bearings and I also use it to pull CC steering wheels. It's sold by Snap-On so if you break it, the replacement is free.
