Old 02-16-2011, 11:53 PM
TommyK's Avatar
TommyK TommyK is offline
Default Pictures I hope
Hey guys, found the cable for the camera, took pics, downloaded pics, shrunk pics so i can hopefully download them here. This is my mutt 108. She has a 126 rear end, as you can see by the serial numbers. Used her to mow the lawn this past summer, bought a blade and wheel weights to plow in the winter. I think the clutch is going. When i plow with her, and i push snow up against a snowbank and come to a stop because of the snowbank, i have to depress the clutch pedal a couple of times to get her in neutral. No other problems with the clutch, only when i come to a stop against a snow bank. Does this sound familiar to anyone? Any help would be much appreciated.
Old 02-16-2011, 11:55 PM
Great looking 108, ya have there!
Old 02-17-2011, 12:02 AM
TommyK's Avatar
Thanks ACecil! Poor girl had what i believe was the original air filter still in her when i bought her, so just changing the filter gave her new life. Oil didn't look too good either, changed it once already, i plan on changing it again soon. I also have a gallon of hytran for a drain and fill in the spring. Gotta take care of that yellow paint on the front end as well. Air filter cover is supposed to be yellow too.
Old 02-17-2011, 12:14 AM
Anytime Tommy! Your 108 has a replacement engine, so the air cleaner is supposed to be black. The original yellow engine had the yellow air cleaner.
Old 02-17-2011, 12:20 AM
Nice one Tommy!! Looks like original paint is in great shape and I'm diggin' those ags and weights on that cub!! Nice pics!
Old 02-17-2011, 05:29 AM
Sweet looking 108!
Have you pulled the clutch to see if the throwout bearing and teaser spring is broken? I'm jsut trying to give you a place to start someone else might have the answer for you.
Old 02-17-2011, 06:02 AM
108cubber 108cubber is offline
Hi, TommyK. Nice looking 108? I have one built 11/71. Did the PO put the 108 Serial #s on the frame (from the old rear axle). Also, looked up the axle #s, and (if I read correctly) they show to be a 126. Frame #s i could make out are 2050043U529111. Axle #s 2050039U324000. Axle showes bulid date 1/70. Frame #s show build date 10/74. Not trying to stir up anything, just don't understand #s on Frame on a 108. I have a 48" deck and love mowing with it. Have a good day.
KennyP
Old 02-17-2011, 06:23 AM
KennyP
I can't answer the serial # on the frame but he did state that it does have a 126 axle in it.
Old 02-17-2011, 07:31 AM
Yeah, I was just trying to be sure that I read the #s right off the pics. The frame #s almost look factory installed, so someone did a good job of putting them there. Looks to be a location of later model #s. Wonder if the frame is a later model and PO put the original 108 #s there to fill the holes? Anyway, looks to be a keeper. Have fun with it, TommyK.
KennyP
Old 02-17-2011, 10:41 AM
TommyK's Avatar
Thanks everyone! Havent' had much time to play with her lately, but i know i have to take a look at the clutch. Thanks for the starting point Duke. i'm sure i'll be looking for help when i take her apart. Kenny, you are correct with the dates for the 126 rear end and the 108 frame. Wanted to share that with everyone, thought it was interesting. I was wondering if anyone had seen wheel weights like those? Cub cadet 75#'s. I was looking for cast iron, but couldn't pass those up.
