Old 02-26-2011, 07:36 AM
mred1121 mred1121 is offline
Question Hydro slow in reverse
Just got a 1994 model 1863 cub the guy said it was a little slow in reverse, but some times it takes a little time to get moving on an incline.
What could I do to fix it?
Old 02-27-2011, 01:02 PM
PurplDodge's Avatar
PurplDodge PurplDodge is offline
See if you can pull up on the brake pedal. Do that every time you let off the brake.
1992 Cub Cadet 1440 1,400 hours, 44'' Deck, 42'' IH Dozer Blade, Light Bar, All Trail tires,
16 year old Cub Cadet owner!
Old 02-27-2011, 04:09 PM
Smile slow in revers
fixed problem, just rod adjustment.
Old 04-02-2018, 10:52 AM
krravi krravi is offline
Hi,
Can you tell me how you adjusted the rod? I have the same problem.
Thanks.
Old 04-02-2018, 11:13 AM
Go in the Technical Library Section and download any of the Service Manuals (ie: 82 Series). Cub Cadet used the Sundstrand Hydro and the procedure is all the same.
Old 04-02-2018, 11:14 AM
Originally Posted by krravi View Post
Hi,
Thanks.
I applaud you for taking the time to look for a solution on your tractor by looking through old threads! But.... this is 7 years old, and the guy whom you are seeking answers from hasn't been on since October of 2011. Probably not going to get an answer from him.
I suggest finding the proper section to post in and start a thread. This time, list the model of tractor you have. That way we know what your working on.
On most models.... the hydro linkage has tie rod ends. They are screwed on the linkage. Pretty easy to figure out.....
Old 04-02-2018, 11:57 AM
Cub had a service bulletin out for slow reverse on the Cyclops series.
Old 04-04-2018, 05:33 PM
Gary C Gary C is offline
Thanks Sam! I just noticed my 1440 is a lot slower in reverse than my 782 is. Looks like some "tinkering" is required.
