Old 03-11-2011, 11:47 PM
127cub 127cub is offline
Default Gonna need some help with this project!!!???
I'm looking into building a FEL for my 127 cub. But I'm not sure what I will need hydraulically. Like what size pump I would need etc etc.
Any one know any thing about hydraulics???
Any help would be appreciated
Old 03-12-2011, 04:56 AM
Originally Posted by 127cub View Post
I'm looking into building a fel for my 127 cub.
But I'm not sure what i will need hydraulically.
Like what size pump i would need etc etc.
Any one know any thing about hydraulics?????????????????
Before you get in over your head I would buy a set of plans. Do a google search for "loader plans" and go from there. I've got a set of plans from P.F. Engineering and they are pretty good. Not the easiest to read but everything you need will be in there. A set of plans will save you lots of headaches and money. Keep us updated on your progress.
Old 03-12-2011, 05:44 PM
If you don't mind sharing Duke what stroke is the cylinders that PF calls for, & what GPM & pressure hydro pump do they call for??? I'm just trying to price out those things to see if I have the $$$$$ to make one
Old 03-13-2011, 12:07 AM
I wish I could share that info. Their plans are worth the cost of them.
Old 03-13-2011, 01:34 PM
Merk Merk is offline
by 127cub
Best thing you can do is buy a set of plans from PF Engineering. They have all the needed infomation and tricks to build a loader that will take abuse. The cost will vary from $1200 to $2000 depending on what pump, control set up and how much hose or tubing you use. The above price includes modified hubs/rims on the front axle.
The plans can be resold when you are done to help offset cost.
Old 05-01-2011, 01:40 AM
the surpus center in lincoln ne has a vast assortment of cylinders , pumps , valves that you already payed for once ( military surplus ) i really want a fel too but do not have anything to scoop
