Old 03-12-2011, 07:34 PM
cub100's Avatar
cub100 cub100 is offline
Default resistor
need help on how to bypass a ignition coil resisitor have located it just need to know how to bypass it since the coil says no resistor required internal resistor so help a man out here!
~austinboy85~ on the youtube tv , quote from my tractor trouble shooting teacher,, " be true to your teeth or they will be false to you" rodney burger!
Old 03-12-2011, 08:18 PM
I'm confused. Why do you want to bypass the resistor? If this is for a Cub, you need the resistor...
Old 03-12-2011, 09:56 PM
cub100's Avatar
because the new coil i got from napa says no external resistor required and yes its for a cub 1000 wide frame (all were wide i guess) but tell what i should do cause im lost!
Old 03-12-2011, 10:02 PM
The coil with the internal resistor is the correct one for a Cub Cadet...just connect it up.
It says 'No External Resistor Required' because it has one built in and does not need an external resistor like most other coils do.
Old 03-12-2011, 10:07 PM
cub100's Avatar
ok ill post pictures then u guys tell me what u think!
Old 03-12-2011, 10:08 PM
cub100's Avatar
does tht mean i can leave the resistor on the engine block unplugged? or keep it plugged in?
Old 03-12-2011, 10:26 PM
One more time...the proper coil for a Cub Cadet has the resistor built in, so you do not need an external resistor. If your tractor has one, someone added it, and you need to remove it when you install the correct coil.
Old 03-12-2011, 11:13 PM
william1041200's Avatar
I know of only 2 plugs near the engine. One is the stator connector to the rectifier- 3 wires: 2 outers are ac28v, center is 12v+. I am pretty sure the aluminum shell is the - . The second connector is a single wire for the electric PTO. As stated before, the coil and resistor are built together.
Old 03-12-2011, 11:45 PM
cub100's Avatar
i seeeeee thank you verry verry much i understand now
Old 03-13-2011, 10:54 AM
If you have an External Resistor installed on your Cub.....REMOVE IT and do not use.
Tags
resistor bypass cub 1000
