Old 03-18-2011, 08:08 PM
TEET's Avatar
TEET TEET is offline
Default 127 grill color?
I have 4 grills here from various 1x7 series tractor, and they are a rainbow of colors thanks to the po's. What was the correct color of these when they rolled off the assembly line? Ive searched quiet a bit, and seen that some are silver and some are black. The one on my 127 now is black.
thanks,
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 03-18-2011, 08:39 PM
They were cad-plated or something like that from the factory.
Old 03-18-2011, 08:55 PM
TEET's Avatar
So, short of re-plating it, a silver color would be closest to original I presume?
Thanks Matt,
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 03-18-2011, 09:23 PM
Yeah, I would think so.
When I was plating bolts for that 100 a couple years ago, I thought of trying to do a 1x4/5 grille insert I had laying around, but didn't have the right size/shape container.
Old 03-18-2011, 10:18 PM
JaysNJcub127's Avatar
JaysNJcub127 JaysNJcub127 is offline
Default color
Both of mine, I painted the same color as the hood, wheels etc.....
1969 Cub Cadet 127
Cub Cadet HDS 2155 w/ bagger
#2 IH cart
48" deck
42" Front Blade
Brinly Sleeve Hitch and Brinly Plow
IH wheel weights
Old 03-19-2011, 12:04 AM
TEET's Avatar
They look awesome Jay! I have the grill om my 73 painted the same way, and it does look sharp...Thanks
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 03-19-2011, 03:28 AM
westofb's Avatar
westofb westofb is offline
If you want a cadium color, search the internet for eastwood products...they sell spray bomb paints to mimic many different coatings such as the cadium mentioned above, raw cast iron, etc. Check them out!
Old 03-19-2011, 11:18 AM
Silver Cadmium
http://search.eastwood.com/search?as...&p=Q&ts=custom
Old 03-19-2011, 06:07 PM
TEET's Avatar
Thanks fellas...I had seen that stuff before when I ordered some Eastwood stuff for my 51' Packard. I also have purchased alot of stuff from Caswell Plating, they are minutes from my house and have the same type of stuff, plus actual plating equipment. I just wasnt sure what the actual color was, I have yet to see a plated one...seems they always take a lot of abuse and get replaced with homeade ones or repainted.
http://www.caswellplating.com/
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 03-19-2011, 07:49 PM
gcbailey's Avatar
gcbailey gcbailey is offline
I used some aluminum/chorme type engine paint in a spray can. I think it turned out decent.
Gary
