Old 03-23-2011, 10:16 PM
Default 50"deck
I have a 50" deck off a 582 that i want to put on a 1650.I know the front hangers on the deck are made to be adjusted for the earlier wide frame mule drives.Will both the mule drive off a 1650 and the center pulley work on it as is?Or do I have to change the center pulley to a 1/2" one?
Thanks in advance....
Up to 530 and counting...
Old 03-23-2011, 10:24 PM
bridgewatertek's Avatar
bridgewatertek bridgewatertek is offline
You are correct, you need to change the center pulley
Jim Bridgewater, KD0FJO Osage, IA
1976 IH Cub Cadet 1650, 44A rotary mower deck, 42" snow blade, QA42A snow thrower, rear blade, cab
Well, that's out of date. Current count is 2 LT1050's, a 76, 1 2284, 1 2130, 1 2135, 1020, and 10 1250- 1650's, with decks, blades, snow throwers, and a Brinly plow
