Old 03-26-2011, 07:24 AM
1966cub102 1966cub102 is offline
Default 129 or 147 ?
I am going to look at a couple cubs today,Looking for opinions on which is a better tractor. pros and cons,Of course condition of them will be most important.I know the 147 is kinda rare,but I dont know how rare a 129 is.
Old 03-26-2011, 08:01 AM
cub cadet people II's Avatar
cub cadet people II cub cadet people II is offline
The 129 is a wide frame and the 147 is a narrow frame, the 129 has a better steering system. I would go with the 129, if you don't need the extra 2hp. I depends on what you want.
Mike
Way too many!: 4 digit Original’s #1218 and #8820, 70, 71, 72 x2, 73, 86, 100, RESTORED 102,105,122,123,124,125,147 with Danco Loader, 149, 1000, 1572 Diesel with 3 pt, (2) 42” snowplows, 54” Haban Power Angle Blade, (2) 38” decks, (2) 44” decks, (2) 48”decks, #1 cart, #2 cart, #3 cart, #4 cart, Brinly Moldboard plow, Brinly Cultivator, Brinly Disc Harrow,3 sets of IH wheel weights, IH Windbreaker Cab, QA36A blower, QA36 Blower,Boxblade, Giant Vac System off a 73!
Old 03-26-2011, 08:26 AM
The biggest "pro" for the 129 is the fact that is is a Wide Frame tractor and a lot easier to work on. Other than that, the merits are about equal.
Old 03-26-2011, 08:51 AM
Why wrack your brain deciding which one?
Buy both!!!Heheheheh
Up to 534 and counting...
Old 03-26-2011, 10:27 AM
wish I could buy em both,as it might be a trade,3500 watt generator for one.In this economy I cant afford to spend the money.If the deal falls through I also have a possible 100 that might be had.Anyone have any pros or cons on the 100?
Old 03-26-2011, 10:52 AM
Not a thing wrong with 100's. Little tanks that keep on going.
Old 03-26-2011, 02:55 PM
Default 129 rear and deck
Well I had a 129 follow me home today,motor runs good no smoke,But I only have reverse no forward.My question is will the trans out of a 782 iron rear fit right in a 129 with little problem? Also will the mule drive and deck bolt on? and as far as the rear might no forward be a simple fix ?thanks
Old 03-26-2011, 02:59 PM
Default 129
I got the 129
Old 03-26-2011, 03:05 PM
Switch the release valves and see if you have forward and no reverse. If so, you have a bad release valve. No need to swap rearends.
Old 03-26-2011, 04:02 PM
Thanks Matt I dont know for sure how it works,But the tunnel cover was not bolted down and when I removed it there was 2 hex bolt looking things with a plunger thing in the center atop the trans one button was up the other was down I am guessing they are the valves your talking about.I had to remove the driveshaft the coupling at the rear is worn so when I fix it I will try again.Sound like the problem?
