Old 03-27-2011, 04:13 AM
Guitar Guy Guitar Guy is offline
Default Steering wheel question
My steering wheel on my new CC seems to be 180 degrees off when the wheels are positioned straight.
Does it just need removed and re-positioned?
Josh P
Old 03-27-2011, 08:21 AM
Only if it bothers you.
Old 03-27-2011, 10:39 AM
steve59's Avatar
steve59 steve59 is offline
Remove the entire tie rod going from the front end to the lever plate on the steering column. Set your front tie rod ends so your tires are 1/8” closer in the front than the rear. Then turn your steering wheel both ways as far as it will go in both directions and count the number turns. Return it straight with the equal number of turns in both directions. Adjust the tie rod ends on the shaft you removed from the front end to the lever plate until the holes line up and your steering wheel will be straight.
Chug a lug a luggin’ 5 miles an hour
On my International Harvester
