Old 04-03-2011, 09:05 PM
william1041200's Avatar
Default hydro controls
Is the hydro cam control supposed to be completely free moving - while hydro unit is out of tractor? Meaning that there is 0 resistance to its movement. Im pretty sure its good, and that the control resistance is in the control lever, but just checking.
Old 04-03-2011, 10:41 PM
young enthusiest's Avatar
Yes it's supposed to be free moving. All is well
Old 04-04-2011, 08:05 AM
Thanks Tyler!
Old 04-04-2011, 08:17 AM
red211's Avatar
red211 red211 is offline
I thought the resistance to hold set speed was in the linkage, my 109 had a allen screw at bottom of lever rod that I tightened a little to add resistance to lever movement. It helped keep it from going wide open if you let go of the lever. The trunion spring was worn and I just put a new spring in, could use a little welding but fits tight enough to work for now, but haven't got it back together to check operation. I am new so I am learning also.
Old 04-04-2011, 04:52 PM
That is true, but the OP is talking about the cam plate on the hydro pump itself, which is supposed to be free to move. The friction adjustment is on the control lever itself.
Old 04-05-2011, 12:17 AM
red211's Avatar
Sorry, your right, I went back a re-read it. Thanks for clarifing.
