Old 04-03-2011, 09:55 PM
Rozell Rozell is offline
Default Carb, timing, rebuild?....not sure what.
Alright. The ol' k341 in the 1650 is running rough. At full throttle its running rough and im seein a significant amount (to me anyway) of blue/white smoke. Its got a new ignition system ( switch, condenser, coil, plug, plug wire, points). I adjusted the timing by using the mark on the flywheel. Yes i know this isnt the prefered way but it was all i could do at the time without a timing light. She idles great but as soon as I idle it up it spits sputters and runs rough. Ive tried adjusting the carb but no luck. Im somewhat familiar with the engine but not near as much as some of you guys on the forum!! Some help would be appreciated!! Thanks fellas
Old 04-04-2011, 12:31 AM
Set your timing using Matt G's static timing guide. Not to sure if that will help your smoking or not but until the engine is timed correctly it's hard to say.
http://www.onlycubcadets.net/forum/s...ead.php?t=4405
I had a K241 that would stumble when it would throttle up. It was a blown head gasket. Head gaskets are like $11 and it would be a good time to remove the carbon build up at the same time. The service manual has the info in it. Have you set the carb to the factory defualts? Has the carb been rebuilt lately? If your 1650 has been sitting a while it might need to be rebuilt. Could be some play around the throttle shaft.
Old 04-04-2011, 04:41 AM
nikster's Avatar
nikster nikster is offline
Just re-viewed the post on Matt's site for setting points & tips.
Can't be any simpler than what is shown.
If I can understand it, that means it's easy.
Nik,
Old 04-04-2011, 02:20 PM
cleon001 cleon001 is offline
I ran into a similar issue on my 1650 when I was doing the Timing and tuning. Check your spark plug gap. The manual says 0.035 but when I put in a new spark plug with it gapped at 0.035 the engine ran great at low idle but would run rough on high speed. I put the old spark plug gapped at 0.020 back in and the engine ran and continues to run smooth and high and low speed.
I also found this in the Kohler Service Manual under the the Governor Sensitivity Adjustments recommended on 6.32 of the Kohler Service manual, where it recommends 2 things to do if the engine is seeking. One, setting the Spark Plug gap to 0.020 and the other of moving the governor spring one hole lower.
Hope this helps.
Cleon
Old 04-04-2011, 08:25 PM
Thanks for all the great info guys, i appreciate the help! When i get off duty in the mornin, im gonna try these things and see if i cant get her to runnin like i know she can!
