I'm looking for a motor for my sons box store husqvarna, it came with a 21 HP B&S ELS that had low hours on it when crank shaft or rod was done in, I pulled the heads, and one side had 1" play up and down on the piston. Being he was not old enough at the time to cut grass, I had a 12 HP B&S for him to use as a small tractor, now he is ready to cut grass, and this husqvarna is a good grass cutter, and above all he can handle it, it has a 46" deck, way to much for the little B&S single cylinder.
Now here comes in the cub, I found a cub cadet on the side of the road, no stickers, no serial, no model, no deck, however it cranks up, runs good, no idea what model it is, it has a 17 HP Kohler Magnum twin, opposed. I was thinking if I could get it cheap enough this would be a good motor for his husqvarna it's model MV18S spec 58520. What kind of money would the motor alone be worth ? The cub cadet may bring some money for parts, no idea what model, and I looked good all over the mower. It's a lawn tractor, small wheels and tires, vertical drive with belt, plastic hood, with black plastic emblem/v looking ornament on front. Anyone have any idea what this is I know vague for sure, the shifter is on the dash right side of steering, 5 speed, and feels looks to be a manual transmission. Also what do you think of the motor, I have read somewhere that some of the Kohler opposed twins would not get oil everywhere when on the side of a hill etc, however I assume this is a full pressure lube, it has a oil filter as well. Thanks for any info you can come up with. Clint |
Ok. I can't tell you what the model of that tractor is because I'm not versed on the lawn tractors, but that engine would be a 18hp magnum. They are great engines but with it being a vertical crank design, it isn't worth what the horizontal engines are worth, mainly because of demand. The only engine that really ahd the bad oiling problems were the kt17 series 1 engines found in the 682/782 tractors. They fixed that problem with the series 2 KT17. Yours would be basically a kt17 with solids state igintion or a magneto and no points. I would say the engine is probably worth $250 if it runs good with no smoke or weird noises.
Hope this helps, AJ
1980 [COLOR="Red"][/COLOR]482- Stock 1981 [COLOR="Red"][/COLOR]582- Mag18, Sleeve Hitch, Spring assist 1979 [COLOR="Red"][/COLOR]682- Mag18, Sleeve Hitch, Spring Assist, #1 Tiller 1980 [COLOR="Red"][/COLOR]782- Mag18, Sleeve Hitch 1983 [COLOR="Red"][/COLOR]982- Stock, Fully Optioned |
I assume it's no longer under the manufacturer warranty?
