My 1811 is in the process of getting the puller wheels and tires. I got the douglas polished front wheels. The bearings they sent me were 3/4". They did not work. What size spindle is on an 1811 on the front? Also, will the aluminum hubs they sent me accept either size? If I know whay size is on it, I can tell them for sure tomorrow when I call them. Thanks, Jason
If the 3/4" bearings were too small, then you have 1" spindles.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
Got a 3/4 and a 1 inch open end wrench? See which one slides snugly over the spindle shaft... that's the size of your spindle.
Quietlines and narrow frames, mostly projects but I mow with a 1200 and have a 122 set up for pulls. Wandering the country bringing towers to wind farms everywhere, and bringing yellow stuff home to Texas. Also into flatfender jeeps. |
The 1811 will have 1 inch spindles.
Sold everything but one. 1211-snow pusher, cab ,54 inch plow, loaded tires (all 4) Gilson wheel weights, X-trac fronts- soon to have power steering and dual hydraulics |
Well the Dougls wheels i got came with 3/4...... I wonder if the 1 inch bearngs will fit in the hubs of the new wheels. Worse comes to worse, couldn't i use the bushings that go onto an old CC original? i think they werwe 1 inch as well. The spindle hud that came with the aluminum Douglas wheels came with 3/4. The hole that the bearng seats in looks like it might not fit the next bigger size in it. Hmmmm. Any thoughts? I know i have seen these 8 inch wheels on the 682/782/1811 type of tractor.
Send the wheels back and get the correct size.
Get yourself a set of early wide frame spindles they are 3/4". All you have to do is switch the spindle's and your good to go. That's what I did on the 1282. Very easy and if you want to put it back to original switch it back. Check with Rich or Chris, at the top of the page they should have them. I don't know where your at in PA but if your close to Rich you can go to his place and pick them up and save on shipping.
2013 cub cadet GTX 2100 w/IH weights 1984 cub cadet 1282 w/#2 cart, plow, IH weights 1970 IH cub cadet 73 w/fenders Haban 402d sickle bar 1966 IH cub cadet 102x2 1966 IH cub cadet 71 pull start w/Fenders IH sweeper, Brinly Gard N Cart 1965 IH cub cadet 100 w/Fenders hydro lift Brinly Gard N Cart, 3 point sleeve hitch Brinly plow sleeve hitch blade #1 cart 1965 IH cub cadet 70 w/fenders and snow plow 1961 IH Cub Cadet Original #3646 w/fenders 3 point, IH rear blade, non trip snow plow |
What early models should I look for to swap the spindles? After talking to the wheel dealer, I don't think I can use my 1 inch ones.
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT Here's a set on epay. I'm not sure what all models had the 3/4" spindle's. The 1000, 1100, 1200, pretty sure the one's from an, 86, 108, 109, 128, 129, 149, and 169 will work. I'm sure if they don't someone with more knowledge of them will chime in. The one's in the epay listing say their from a 1250 but I thought they were 1" but I'm not sure. I don't mess around with the 1x9 or quiet lines much so I hope this info. isn't to far off. If you call Rich or Chris and tell them you need a set of 3/4" spindle's for a wide frame, I'm sure they will hook you up.
Some of the earlier quietlines had the smaller spindles there's a serial number break somewhere
Adrian 2072 (789513) |
