Old 11-14-2015, 12:59 PM
Originally Posted by bocephus1991 View Post
I've had a new coil out if the box be no good.
thats an excellent point, just because a part is new doesnt mean its functioning properly. ive gotten to the point where anytime i replace a thermostat i always check it with a heat gun to make sure its opening before i install it, i had 3 bad ones in a row from a reputable brand.
Old 11-14-2015, 03:56 PM
Trekrider60's Avatar
Trekrider60 Trekrider60 is offline
I checked the coil according to Roland's diagram and it is only 1.5 ohms between the + and - terminals instead of the 4 - 8 ohms and only 2000 ohms between +terminal and center terminal . I'll get that changed on Monday and get a new condenser also.
Gene
149 w/Front Blade
Old 11-14-2015, 08:21 PM
You got the fuel economical Kohler. Only runs on idle and doesn't burn much fuel. Hope you figger er out.
Old 11-17-2015, 04:16 PM
Glad to tell you all we are up and going. New coil, points, condenser, plug, and static timing plus the carb cleaning and new fuel filter and it is running great. The old points look okay, but just change them out along with the conderser. As a bonus, my old problem of running at 3000 rpm at half throttle is gone. I can throttle up nice and smooth without a problem. I have it set at 1300 rpm at idle and 2700 rpm at full throttle. This is a great site and I thank you all again for your suggestions.
Now to get the front blade and rear weight on before the "four letter word" gets here.
Gene
149 w/Front Blade
Old 11-17-2015, 04:18 PM
Pretty sure full RPM should be around 3600 RPM's
Old 11-17-2015, 04:22 PM
I know I'm low at the high end, but it runs fine for what I do and I figure it is a littler easier on the old engine.
Gene
149 w/Front Blade
Old 11-17-2015, 05:30 PM
cubby102's Avatar
cubby102 cubby102 is offline
Im sure its already been brought up i didnt read the whole thread. I had a 102 do yhis same exact thing after cleaning and tuning the heck out of the carb i ended up finding out the condensor was bad
Old 11-18-2015, 03:30 AM
Not if you load it at all. You should set the engine to run 3600. If you don't want to run it that fast, don't push the throttle all the way up. Better to have it if needed than to lug it because you can't run it where it's designed to run.
