Old 03-07-2012, 09:06 PM
IHCUBCADET's Avatar
IHCUBCADET IHCUBCADET is offline
Default Gear Drive Trany Oil
Looking to change transmission oil in my 108, the mnual said only add as needed but i see people do it all the time so I guess I will too. What oil to use? And where to get it. I am looking for a quality oil to put in this trany. Thanks for the help.
International Cub Cadet 71 with deck
International Cub Cadet 108 with plow, deck, chains, single bottom plow,Sleeve Hitch.
IH Cub Cadet 122 project
Case 444 withs ags, plow
Old 03-07-2012, 09:11 PM
HyTran just like the hydro's use. Your Cub Cadet dealer will have it. It takes 7 pints to fill a manual transmission.
http://www.onlycubcadets.net/forum/s...ead.php?t=4634
Old 03-07-2012, 10:26 PM
SwampRatt-1977's Avatar
In the Ih service manual for 70/100 it says hytran OR SAE-30 Motor oil. gear drives are pretty hardy, im going to use sae30. i hope i didnt start another fluid fight lol
Old 03-07-2012, 10:55 PM
That is right, Original thru 1X4/1X5 can use either. Hytran in everything else except an original with a Danco UD-6 creeper unit. That requires SAE-140.
Old 03-08-2012, 05:31 AM
This may be of additional help..... Chart
Old 03-09-2012, 06:18 PM
MOturkE's Avatar
MOturkE MOturkE is offline
I'm using SAE 30 motor oil in my 122 and have noticed much improved performance compared to the water-infused mess that was removed from it. It was not easy to roll in neutral when I first bought it. No problem now.
Proud to own a 1965 Cub Cadet 122.
Old 03-09-2012, 06:28 PM
cubfan's Avatar
cubfan cubfan is offline
Well I suppose I know what I will be doing in the very near future too.Been wanting to do the same thing to mine and was wondering the same question.Now I know,thanks to all!!!
Old 03-09-2012, 06:31 PM
OK some needs to explian to me why a good syn gear oil wouldn't be better than HYD oil.
Old 03-10-2012, 07:26 AM
steveyrock's Avatar
steveyrock steveyrock is offline
I am sure many owners of these gear driven tractors put in what ever they had. My 106 had some heavy gear oil in it before I changed it with Hytran. I put 30 wt in my 122. They both operate good and shift nice.
122-snow blade and 42 deck, wheel weights, fluid filled tires,chains
106-42"deck
1250-44 and 50" decks
147-44"deck
2155-42"snowblower 38"deck, chains,suitcase weights
Exmark Quest-zero turn 42"deck 23hp Kawasaki engine
