Old 04-06-2009, 10:41 AM
cadurning's Avatar
cadurning cadurning is offline
Default Optima Battery
Anyone have experience with Optima batteries. I'm going to replace battery in my Alfa soon. In this car the battery is mounted in the trunk and leaky batteries over the years have rotted a hole in the spare tire well. I'm going to fix the damage to the tire well and hopefully find a battery that dosen't leak.
Any thoughts on the battery?
"If it's in the newspaper it must be true." Dudley Do-Right
Old 04-06-2009, 10:56 AM
young enthusiest's Avatar
YES YES YES! OPTIMA! its a little spendy, like $200 or somthin, but the cranking power, and the non, leak, spirocell 6-pack is sweet!
Old 04-06-2009, 04:49 PM
CBH's Avatar
CBH CBH is offline
I have had 2 Optima batteries in my boat, and both went bad! I thought that the first one was just my bad luck. Sears checked it and found it was bad, then exchanged it for a new one. It went bad too! They gave me my money back and I turned around and bought a Diehard for half the cost of the Optima. It's been in there for 3 years now and still going strong.
Old 04-07-2009, 11:55 AM
klejeune's Avatar
klejeune klejeune is offline
I've heard the new red top's aren't as good as the old one. The yellow top are still holding up though.
I like pie
Old 04-07-2009, 12:21 PM
dyt4000's Avatar
dyt4000 dyt4000 is offline
You can also use a Miata battery...
Co-Founder
You only need two things in life...duct tape and WD-40
If it's stuck and needs loosening, use the WD-40.
If it's loose and it's suppose to be stuck, use the duct tape.
Old 04-07-2009, 03:48 PM
cadurning's Avatar
David,
Is the Miata battery a dry cell?
Old 04-07-2009, 05:16 PM
murphycc
Guest
Posts: n/a
I have an Optima in my truck and I've been happy with it. Since 04.
Scott
Old 04-08-2009, 08:27 AM
dyt4000's Avatar
Originally Posted by cadurning View Post
David,
I believe it is...but it still has vent tubes that go out the bottom...
Co-Founder
Old 04-08-2009, 10:21 AM
DrBailey's Avatar
DrBailey DrBailey is offline
I had a six pack in my coupe , it was always dead , also got a free replacement.
I later found out that they are a awesome battery if it is in use daily, when they set and set like a street rod car they drain down.
thats what the battery co. told me anyway. The acid battery in the car now is two year old and always up and ready.
Dont Junk It, Restore It
Have a good day, Doc
