Anyone have a good source for spiral pins? I need one for my qa-42a, but neither my local NAPA or hardware stores carry them.
Ian Mine: 72 w/ k301, 3 125's, 1 w/ hydro lift, 38,42, & 2 48 decks, 2 42 front blades, QA-36a & QA-42a thrower, tiller, lo-boy 154. Also, LOTS of parts. family's:2 105's, 2 106's, 149, 2 lo-boy 154s, Farmall Cub. Non-IH: 1940 JD Model A, 1954 JD 40 U, 1955 JD 40 Crawler, 2 1956 JD 420 U's, both w/ Henry Loader and Backhoe. JD 110. Wheel Horse (model unknown.) Power King 1614. We love our tractors! ![]() |
Do you have an Ace or True Value, maybe a Menards near by? They should all have them, I get all mine at True Value.
-Ryan
I buy mine at the local hardware store that used to be an Ace. They are in the Hillman parts section along with keystock and rod ends.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
![]() Quote:
to rebuild my clutch. They worked great! http://www.mcmaster.com/#spiral-pins/=q71ymm
1966__122 Cub Cadet. Owner: Calvin, 6 yrs old Dad: Craig |
Every time one of you guys posts a mcmaster-carr part number, I go there, buy some of them, and find about $100 of other stuff I need. Just reading this forum is getting expensive!
![]() Quote:
With the prices McMaster charges, it's not hard to get to $100! But when it shows up the next day on a brown truck it eases some of the pain.
Thanks guys! I had high hopes but my local mom & pop stores only carried standard roll pins. I do have a true value that's not too far out of the way, I'll try them too. If I have no luck there I'll go to Mcmaster.
For now, I'm going to use a hardened spring steel roll pin that I bought at the last hardware store I went to. I couldn't help it, the little old man looked around for one for at least 15 minutes for me, and could only find that. I felt I at least owed it to him for his time. it only has to last the winter, planning to refurb the thrower in the spring anyways.
fleet farm or farm and fleet will for shore if ones neer you or tractor supply, fastinall
