Old 06-25-2014, 02:58 PM
cfiles cfiles is offline
Default 50" deck rebuild
So I picked up a 1872 some time ago and i'm finally getting around to rebuilding the deck on it. I like looking at others pictures, so here are some of my progress.
[ATTACH][ATTACH]IMG_2390.jpg[/ATTACH][/ATTACH] Messed up some threads on all three spindle shafts.
Old 06-25-2014, 03:05 PM
Then i got parts back from sand blaster, and cleaned up the rest.
Old 06-25-2014, 03:13 PM
I plan on replacing bearings, seals and top nuts on spindles. I wound up with two good spindle shafts. And I have one of the " pump bearings" that is good off of another 50" deck. Is there a reason I couldn't use the pump bearing on one spindle (middle) and the shafts on the other two? Also, is the seals the same part # on the pump bearing?
Old 06-25-2014, 03:15 PM
Good work! Looking forward to your updates.
Old 06-26-2014, 06:16 AM
X2!
Old 06-26-2014, 07:14 AM
Nice work, also looking forward to updates.
Old 06-26-2014, 08:03 AM
sbauerz28's Avatar
Nice job on the deck. It looks better than mine did. The more I hit mine with the wire wheel the more pin holes I found. Atleast my bearings and spindles were all good so that one less thing to fix.
Old 06-29-2014, 08:35 PM
Got a lot of parts painted, wet sanded and repainted. Waiting on bearings and seals. Still need to order couple pulleys. Some progress pics. [ATTACH]photo 4.jpg[/ATTACH][ATTACH]photo 2.jpg[/ATTACH]
Old 06-29-2014, 08:54 PM
looks good,I have few you can do here.
How much did the blasting run yah?
Up to 534 and counting...
Old 06-29-2014, 10:04 PM
Originally Posted by cfiles View Post
Got a lot of parts painted, wet sanded and repainted. Waiting on bearings and seals. Still need to order couple pulleys. Some progress pics. [ATTACH]Attachment 53423[/ATTACH][ATTACH]Attachment 53421[/ATTACH]
Looking real good!
