Old 05-11-2010, 10:32 PM
TEET's Avatar
TEET TEET is offline
Good for you Rich! See, with a little persistence, and some trial and error you surprised yourself... Clean her up and post some more pics, it would be nice to get a good look at your new baby :biggrin2.gif:
Oh yeah...I got the 682 up and running today, and she runs and drives like a champ. I surprised myself too...the engine was from a 1250 that had been sitting for 5+ years...
Thanks again!
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 05-12-2010, 07:03 AM
fer100's Avatar
fer100 fer100 is offline
Jeff that is great you got that 682 running good job. This weekend i'll clean her up and post some pictures you do the same. I might try and post utube video Rich
,1 Ariens 934 Hydro with cyclone rake
Old 05-12-2010, 10:10 AM
Turbo Archie's Avatar
Turbo Archie Turbo Archie is offline
So why wasn't it running and what did you do to it??
Now I'm confused..
Old 05-12-2010, 07:12 PM
fer100's Avatar
Now I'm confused..
I tend to believe that it was a dirty carb inside and out from not being used. But here is a list of things I did to get it going:
1. Put battery in it, 2. cleaned all electical ends, 3. gap old plug, 4. put new plug in when it didn't start, 5. gaped points about 3 different times, 6.took old gas out of tank and lines, 7. Cleaned and recleaned carb about 4 times (I just didn't want to take it off motor yet), 8. Finally at a last resort got a new can of carb cleaner and sprayed it clean and scrubbed inside and out. Then it finally started. I did all this over 2 days and I believe letting it soak was a key trick to freeing up what ever was wrong. And I just GOT LUCKY.
Old 05-12-2010, 07:59 PM
Stitch's Avatar
Stitch Stitch is offline
The 3pt and the creeper gear are worth dang near what you paid for it, so I'd say you did well.
Killin deers and drinkin beers
Old 05-13-2010, 01:47 PM
So you were in the same boat as me.
I almost started replacing more ing parts when it was really still a gas problem..
Old 05-13-2010, 06:13 PM
piecrazy4 piecrazy4 is offline
Sounds like the main jet and passeges were plugged.
