Old 10-24-2014, 09:48 PM
zling zling is offline
Default Rear weight bracket/cargo rack
had this weight bracket I made a while back to hold 2 cement blocks for help with plowing snow. This summer I got a FEL 128 so it ended up on it and I've been messing around in the woods with it clearing trails and cutting firewood so i decided i needed somewhere to carry my saw, fuel can, oil, tools, ax etc. So heres what i came up with just painted her up will get it all mounted up tomorrow. let me know what you think
Old 10-24-2014, 10:43 PM
bocephus1991's Avatar
Looks like it should work! That second to last pic it looks like a BBQ grill! Put done burgers on and grill supper while you mow or move dirt!
Brian
Old 10-25-2014, 12:19 PM
finished pics or at least finished for now
Old 10-25-2014, 05:33 PM
Looks like a well thought out solution to me.
Old 10-25-2014, 06:29 PM
Thanks it go a lot of use today works great for firewood duty pulls logs really well but for that work I prefer my 148
Old 12-22-2014, 08:08 PM
IHCadetCollector's Avatar
IHCadetCollector IHCadetCollector is offline
Good idea but, too much weight abd every time you hit a bump you'll be popping wheelies!
I lost track of what I own a long time ago!
Old 12-28-2014, 09:46 PM
too much weight? no such thing especially with a loader on the front.
Old 12-28-2014, 09:58 PM
That's what you think..... till the thing between the loader and the rear bracket decides it wasn't made for that kind of weight.
Old 12-28-2014, 11:03 PM
I beef up everything on my tractors they are far from stock underneath. I like pushing the limits of these old cubs
Old 12-29-2014, 12:26 AM
On the frame? Or did you install larger bearings in the rear axle tubes, maybe larger diameter axles.....
In your pics I don't see 5, or even 4 bolt wheel hubs on front, so your still running on a 3/4" axle shaft. Even if you upgraded to a 1" one, it's still too small for all the weight of a loader with a load on it. How about the front pivot rod on the axle? Is it larger?
As far as I'm concerned, a FEL on a stock GT is just an accident waiting to happen. Just not big enough for that kind of load. SGT.... they are a little better to put one one. If nothing else, longer WB makes a huge difference. I just hope you don't find the weak point when you have 7-800# hanging on the front. It is a tractor, but not a big tractor.
