Old 12-28-2014, 04:44 PM
mudpatrol1's Avatar
mudpatrol1 mudpatrol1 is offline
i will have closer pictures tommorow,i did power wash and remove the engine so far.thanks to everyone thus far for replying to my questions
Old 12-29-2014, 04:56 PM
mudpatrol1's Avatar
Default 1863 pictures
here is a few pictures of the rust from leaking battery
Old 12-29-2014, 04:58 PM
mudpatrol1's Avatar
Default more rust pictures
spent a few hours today tearing down the 1863 further assesing things.
Old 12-29-2014, 05:44 PM
Looks nasty,how is the fender pan?
Old 12-29-2014, 07:42 PM
mudpatrol1's Avatar
amazingly enough its good,it even shined up with the buffer
Old 12-29-2014, 07:43 PM
I had an 1864 in that shape, or worse. I found a 1641 with a bad engine that had good paint on it and swapped all the parts over to 1864.
Much easier to do that than chip through all that rust.
Old 12-29-2014, 07:58 PM
I plan on parting this when I get time. It runs good, it has 900 hours on it. Look at post #17
http://www.onlycubcadets.net/forum/s...506#post302506
Old 12-29-2014, 08:52 PM
mudpatrol1's Avatar
i had thoughts of doing a swap,depends what i find.....
Old 12-30-2014, 10:14 AM
FrankF3's Avatar
FrankF3 FrankF3 is offline
I had a similar battery problem with a 782D I had years ago. I washed everything down with a baking soda solution to neutralize the acids that were still on the parts before I painted them up.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 12-30-2014, 05:23 PM
mudpatrol1's Avatar
sadly most of these parts are beyond cleaning and painting. thanks to a member here i got a nice used frame and dash tower
