Old 01-09-2015, 08:00 PM
danfeste danfeste is offline
It has a nut welded to the inside of the frame at least on this 147. I think its factory this way but not sure about other models.
Collection: 100, 71, 128, 169, 582, 682, (2) 782. 1980 Scout Traveler Diesel.
Old 01-09-2015, 08:02 PM
drifter drifter is offline
Originally Posted by danfeste View Post
It has a nut welded to the back of the frame at least on this 147. I think its factory this way but not sure about other models.
Well that explains that. I'm going to bust out the welder tomorrow.
Old 01-09-2015, 08:03 PM
Originally Posted by OldSkull View Post
Danfeste your the man! Those are include in the adapter package the manual make reference too.
The 2 owners before me must have miss placed them over the last 40 years lol. I knew it was something stupid.
Old 01-09-2015, 08:11 PM
OldSkull's Avatar
OldSkull OldSkull is offline
As long good guys shim in and help you working this out that's all that count! Enough say! Get that cub back to work ASAP!
Gilles.
1963 100 (red)/in storage
Old 01-09-2015, 08:18 PM
you need the special lift rod though...
Old 01-09-2015, 08:19 PM
Thanks guys
Old 01-09-2015, 08:21 PM
I have hydro lift. I think I may be ok.
Old 01-09-2015, 08:39 PM
If its going to be installed on 70 100 102 122 123 you won't be able to weld nuts to the inside of the frame for the front hole. They will interfere with the grill casting that needs to slide on the inside of the frame. I'm not sure if that is the case with the 124 series tractors.
Old 01-09-2015, 09:15 PM
My former 122 and both my 125's have the welded nut inside the frame.
My 122 with the QA42 attached with my quick attach tabs . Notice the bolt in the rear hole.
Old 01-09-2015, 09:37 PM
Only the middle bolt has a nut welded. Newer models have the third one welded also and uses a shoulder bolt I believe.
