Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Kubota Engines
Old 01-23-2015, 09:58 AM
FarmFresh's Avatar
Default pretty close to being the same
I put a tape measure on the d600 and the d722 and they are almost the exact same dimensions. They are both mounted in tractors so it was a little difficult to get a good measurement, but the blocks front to back are the same, and the exhaust ports appear to be the same. both of mine have the same harmonic balancer bolt pattern. There are a few brackets and casting differences. The valve cover is a little different, but my d722 is a 2004 model year and the d600 is in a 1512. I could not measure where the engine cradles bolt on but even if those bolt patterns are not exact a drill could fix that. I would say for the money that d722 is a good deal. I can't wait for mine to be done because i feel a turbocharged d722 in a 982 will be fun. Good luck with the project.
149 Raised Bed Tractor
1512 Being restored
1450 Missing its heart
Original 1961 Red No options
782D Missing Engine
Old 01-23-2015, 10:35 AM
Thanks guys! I'll probably get it and that is good to know it is about the same size. I have a 640 out of a 1772 I got from Sam so I hope I can copy the engine cradle and use it in the 982. I've been thinking about adding a turbo to a diesel for sometime now but I know it's kind of a waste but I think it would be pretty cool.
Old 01-23-2015, 11:15 AM
Hence my little disclaimer. I didn't realize they made larger 3 cylinders. Was going more by the pics of the D722. Never seen one in person. Once FarmFresh measures both of his, we'll have an acurate answer and not my guestimate. I'll have to measure the block in the B3300. It's a 4 cylinder but can't remember the actual number off the top of my head. Learned something new today.
I wasn't picking on you. I think the 3 cylinders go clear up to around 2200CC.... Not 100% sure though. Kubota is one of those company's that make so many engines. Plus, there is no good way to look them up without an application. All the other tractor/engine companies have good ways to look up just an engine: Deere, IH, Cat, Cummins.... Not Kubota. Measure your 4cyl and post dimensions, I'm curious.
I agree with Josh and Sam, Todd. Anything under $800 is a pretty good deal. I don't like to pay much for non-runners either for the same reasons. They can get expensive to fix quick. For the record; I've overhauled far more Yanmars than Kubotas. They really are good engines. Let us know how you fair! (As if you wouldn't. )
Old 01-23-2015, 11:46 AM
cub123's Avatar
cub123 cub123 is offline
Hope you get it!
I'm keeping my eyes open for the 722T, the turbo/ manifold looks like it would fit perfect in an 82 series, I'm trying to find part numbers for the manifold and turbo, but haven't had much luck.
Old 01-23-2015, 02:51 PM
red56turbo's Avatar
Don't worry Jon. I didn't think you were picking on me. I'd let ya know if I thought you were. I was just throwing out a guess since I didn't know they made larger 3 bangers. I've seen the 2, 3, and 4 cylinders before. Just not bigger 3's. I'll have to go out later and get the actual number off the block and measure the length. It is good to know the D722 is the same size length wise as the D600/640's though.
Hope you get it!
Here's a couple turboed D722's I saw yesterday while checking Epay to see prices. They are low houred, pricey, and don't know if they sold. They are in the completed listing. Too rich for my blood.
http://www.ebay.com/itm/Kubota-d722t...p2047675.l2557
Josh
Diesel Cub Cadets...........
Old 01-23-2015, 06:43 PM
ken6x6's Avatar
ken6x6 ken6x6 is offline
Hope you get it!
ive spent way to much time looking for part numbers for the turbo and manifold for the 722t. i did find out that it was apparently called a high altitude kit. but that led to another dead end.
keep searching maybe one of us will get lucky
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 01-23-2015, 11:21 PM
red56turbo's Avatar
Finally checked my newer Kubota B3300. It's a four cylinder rated at 33 horsepower. It has a V1505-ES-D24H according to the manual. Hard to measure with a loader and side panels in the way. So kinda eyeballed it at roughly 15 inches, not including the timing gear cover. The D600 in the 1572 was, once again roughly 10 inches. So 5 inch difference between these 3 and 4 cylinders. I'm gonna have to research around and learn some more about these Kubotas not in cubs, especially the larger three cylinders.
Todd,
Any new news about the possible purchase?
Josh
Old 01-24-2015, 06:30 PM
I'm going tomorrow to look at it. If it looks okay and has all the stuff he says it has, it will probably come home with me.
Old 01-25-2015, 12:29 AM
Now we know!
Old 01-25-2015, 08:50 PM
Welll, I got it. Got it home and tried to start it. It has a mechanical fuel pump that I don't think works, rusty water in the fuel lines and the freaking injectors were loose. I put new fuel lines on it, borrowed an electric pump off of another machine and hooked up all the electrical stuff needed....no go. I know you're not supposed to touch the injectors but they were loose so somebody already messed around with them so I pulled them out(fuel was leaking from one) and blew them clean with air(prolly not supposed to do that either) and put them back in tight. I cranked it, cranked it and cranked it...won't start. Cracked open a beer, took a break and loosened the lines on top of the injectors to purge any air out and snugged them back up. Cranked it again and it runs, it runs good with no smoke and has great response on the throttle. BINGO! I then did the snoopy dance!
