Old 02-01-2015, 09:00 PM
Dadenstein Dadenstein is offline
Default 149 Lift Problem?
Hi guys, I have a 149 with a 42" plow, and it won't lift the plow more than about an inch. I can clearly see the piston has full movement range. Any ideas?
Old 02-01-2015, 09:13 PM
Did you check for broken spirol pins in the rockshaft?
Is your lift rod the correct length?
Old 02-01-2015, 09:16 PM
Jeff, the lift rod is the correct length, i don't know about the pins
Old 02-01-2015, 09:40 PM
There may be welds instead of spirol pins ( I have narrow frames myself ) but you should get more lift.
Old 02-01-2015, 09:46 PM
jeff, the pins and shaft are fine. any other ideas?
Old 02-01-2015, 09:48 PM
could this be a problem?
Old 02-01-2015, 09:51 PM
They can appear intact when in fact they are sheared.
Old 02-01-2015, 09:53 PM
kostendorf's Avatar
A picture or video of the moving parts involved would be helpful.
Old 02-01-2015, 09:56 PM
How would i do a video? same as a picture?
Old 02-01-2015, 10:07 PM
kostendorf's Avatar
Take a video then put it on youtube and copy and paste the url here.
https://www.youtube.com/watch?v=s5Wj-zbS_V0
Tags
149, hydraulic lift
