Old 05-07-2016, 05:49 PM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
Default Power steer column
does anybody know the part number for rebuild kit for powering steering. my leaking like a river the only thing I didn't rebuild
Old 05-07-2016, 07:42 PM
Sorry but my crystal ball comes up empty unless I put in a model number.
I would suggest you find the model number of what ever you are working on and try WWW.partstree.com or if it is a
cub cadet you could try cub cadet parts.
Then you could try cross referencing to find the best price, google works wonders, Luck!!
Old 05-07-2016, 08:01 PM
sorry guys 1872
Old 05-07-2016, 08:14 PM
John Deere is AM107078 -- Pretty cheap here.
http://www.amazon.com/John-Deere-Ori.../dp/B00CSBVPGW
I'm gonna try this one next. Steiner 21-SK000011
http://www.messicks.com/search?q=21-SK000011
Parker #SK000097
Old 05-07-2016, 09:03 PM
thank you sir
Old 05-08-2016, 05:23 PM
malchren's Avatar
malchren malchren is offline
would that work for a 1862 power steering column as well? Also does anyone know who rebuilds the power steering cylinders in CT or some place I can send it to be rebuilt.
Thanks
I think we all got yellow fever at this point.
Old 05-08-2016, 06:00 PM
Probably the same parts for the control valve / pump. Member cubs-n-bxrs has rebuilt the steering cylinders you may want to PM him. I know he cuts them apart in a lathe then replaces the seals and welds them back together.
Old 05-08-2016, 10:35 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Where is it leaking from? When I got my 1772, it was dripping 2-3 drips per minute from the steering column. I found I had a bunch of loose fittings where the lines connect to the column. Once I snugged them all up - no more drips.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
