Im going to make it wider by cutting and re welding it with a 2 inch wider piece of steel
Cub Cadet 149 w/ sleeve hitch, rototiller, snowblade and deck, Cub Cadet 124 w/ sleeve hitch and deck Cub Cadet 1811 w/ deck and 18 big internationals 🇺🇸 🔧🐂 ![]() Brinley PP-100 plow Cyclone Rake |
You will have to do some bending on the rear mounts so that they will fit right, and IIRC, make the notches where it attaches deeper. Your really better off trading someone plows or frames. |
It's not long enough either.
Ok.... it's the other way. I couldn't remember. The NF mounts are shorter... I knew they were different length, but couldn't remember which way.
Please find the correct one for your machine and pass the one you have to someone who needs it, they aren't making them anymore.
Okay I wont vichously cut and abuse my plow subframe ill call the local bone yard tomorrow the guy that runs it has a quite a few hes parting out. If I dont find one before thanksgiving break its the plasma cutter and welding wire for that poor subframe
You could also post in the wanted section of the forum if the bone yard does not work out. Cub Cadet 123
