Old 05-31-2017, 09:13 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
If you want a tiller, you need to go with the 2B. It was the one made for an 1812. If you're thinking about going to the rear PTO 3pt 48" tiller.... obviously you don't have the rear PTO. Plus, it's a load on the chassis for the SGT tractors with a longer frame and more weight out front. I don't know that you could even carry that tiller with a GT. Stick with what was made for the 1812.
Oh but Mr Jon... A gt will handle far more weight than the sgt tiller
1- 1200 in pieces
1- 1864 in pieces
Old 05-31-2017, 09:23 PM
Only if you build the hitch. That's an unfair comparason, lol. Remember, a stock GT runs lower pressure than a SGT.
Old 05-31-2017, 09:35 PM
Rescue11's Avatar
Yes, your right
1- 1200 in pieces
1- 1864 in pieces
Old 05-31-2017, 10:50 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
My master plan for a tiller is to get an old front tine tiller and convert it to go in the 3 point, they can be had fairly cheap and the modification should be simple as long as you have access to a welder.
Tim, if you build a big enough Red Green style, rear mount tiller, I can almost guarantee your tractor WILL pop a wheelie!
Queen Of The Quietlines!
Old 06-05-2017, 11:47 PM
Cookieone's Avatar
Cookieone Cookieone is offline
I have my 3 point hitch finished. I haven't fabbed up my lift arms yet. I did mock up some 1 1/4"x3/16 flat bar and used some turnbuckles to raise and lower. Everything seems to to work as it should. I'll post up pics of finshed product when I get everything installed.
1812 custom cat0 3point hitch, foot pedal, 2155 JI Case 470 shuttle speed.
Old 06-05-2017, 11:52 PM
Cookieone's Avatar
Unbelievable how strong those little cylinders are. The pin at the ram worked out and jammed up against the frame and bent the pin. 1/2" pin
