Old 07-28-2017, 09:18 AM
Terry C's Avatar
Terry C Terry C is offline
Originally Posted by smalljob View Post
Thanks guys. I appreciate the comments and suggestions. I originally had the front retainers yellow, but I didn't 't like the look. I am thinking. that maybe zinc colored like the rear lug nuts might be the way to go.
I too don't like the yellow. Zinc is good. Don't tell anybody but I painted some black and like that one the best.
I looked and looked at your pics and tried to keep an open mind about narrow tires, but I just can't. I'm a wide tire guy. Your work was outstanding and mean no disrespect at all.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 07-31-2017, 09:46 PM
smalljob's Avatar
smalljob smalljob is offline
Got the fenders on and I cleaned up the front wheel bolts.
Old 07-31-2017, 11:12 PM
Looking good.
Old 07-31-2017, 11:34 PM
Like it, good work.
Old 08-01-2017, 08:04 AM
Wow, that looks great! You did a fine job on that smalljob.
Old 08-01-2017, 08:10 AM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Very Very nice!! amazing what some fenders can do for those early ones!
Jay
Proud owner of the following:
Old 08-01-2017, 08:36 AM
How about a close-up photo of the wire harness routing out from under the battery box, to the fan shroud and down into the frame??
I'm working on a 100 that I picked up at RPRU in June and it has issues in that department.
Good luck your 100, they are great little tractors.
Old 08-01-2017, 10:38 AM
smalljob's Avatar
Sure thing. Here are a few pictures. Kind of hard to get good angle. Let me know if you still have questions. I don't think I am 100% correct. I think the clip I have on the side of the engine is not correct. I think there is suppose to be a clip on the bolt that holds the S/G, but I like the way it routed.
I also included a diagram that shows how things are suppose to be routed. If you can't read the diagram send me a PM with your email address and I will send you a larger file. I had to convert this to jpg as the pdf was too large to include here.
Bill
Old 08-01-2017, 12:22 PM
john hall's Avatar
That is a very nice looking machine!
So, whats next?
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 08-01-2017, 12:27 PM
jcsmith jcsmith is offline
Default Bee-utiful 100
Bill, your 100 turned out awesome. Beautiful work.
Chris
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
