Old 05-08-2018, 06:41 AM
drcjv's Avatar
drcjv drcjv is offline
I was just kidding about running it. I am very disappointed though, I bought this tractor from another OCC member and I am pretty sure he knew it was leaking.
Charles________________________
1572 3pnt, rear PTO, 50" deck
1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow
1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow
2072 3pnt 50" deck, Brinly Plow
2072 50" deck
Cub Cadet Tank 50 Zero Turn
Cub Cadet 33" Commercial Walk Behind
1953 Ih Cub with just about every implement
New Holland TC33D with Loader and Backhoe
Old 05-08-2018, 06:46 AM
sorner's Avatar
sorner sorner is offline
Where in PA are you at? I could take a look at it. I have a 1912 with an Onan engine right now doing exactly the same thing.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
Old 05-08-2018, 06:51 AM
drcjv's Avatar
Steve I am near Valley Forge.
2072 50" deck
Old 05-08-2018, 07:18 AM
sorner's Avatar
Oh... that’s about a 2 hour turnpike drive one way.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 05-08-2018, 07:52 AM
goonpeden goonpeden is offline
I had a Bad oil leak on my M18 and was ready to pull the motor to change the rear seal and found the breather hose going into the air cleaner was broken and inside the breather the rubber disc was was not attached. Oil was being pumped out and blown all over engine. Replaced hose and breather assembly and motor is going on two years with no leaks anywhere
Just a thought you might want to check this before pulling engine. Good Luck! Bill.
Old 05-08-2018, 08:25 AM
It's pretty clear by the amount of oil and where it is that this is a rear seal issue.
Old 05-08-2018, 08:28 AM
CNH-320 CNH-320 is offline
Charles, that looks like to 2072 I sold you in the summer of '16? If so, I can assure you it was not leaking when I had it. I did replace the crank seal on the PTO end, and I mowed with it several times and had no other oil leaks.
982's, 782
JD 318's, 332 & 420
Farmall Cub & Ford 8N
Old 05-08-2018, 07:58 PM
rwairforce rwairforce is offline
Yep, it's a seal. They all go bad given enough time.
Pull the engine and replace the seal. It's also an inexpensive fix.
You'll have the opportunity to clean it up real nice with the engine out.
You might want to check the driveshaft too since it's right there.
Have fun.
Randy
Cubs: 71, 72, 127, 149, 1440, 2186 and 1864
John Deere 110 round fender
John Deere 140 H3
Sears: GTV16
Old 05-12-2018, 02:49 PM
drcjv's Avatar
I'm sure this will go over like a fart in a space helmet on the forum. I put some bars leak stop in the 2072 today. I am unable to fix right now so I'll see what happens. Hopefully I can fix in the winter.
2072 50" deck
