Old 05-13-2018, 12:27 PM
According the the Fram site, it was designed for "engine oils", says NOTHING about hydraulic fluids.
Old 05-13-2018, 02:26 PM
ironman's Avatar
ironman ironman is offline
I'm curious, I've sent the following message to Fram's Customer Support. I'll post results if/when I get any...
"My question is about your filter PH2844. Your web page for this filter gives comparison information for filters such as Cub Cadet 923-3014, NAPA FIL-1410, WIX 51410, and others which are hydraulic filters for garden tractor transmissions. But your product description for the PH 2844 says "Designed for use with conventional oil" Is the PH 2844 a hydraulic oil filter or a motor oil filter? Thank you.
Old 05-13-2018, 10:03 PM
I can't say it any other way.
Old 05-14-2018, 11:18 AM
Mr Bob's Avatar
Mr Bob Mr Bob is offline
Default filter
Roland, I did not think to look at your filter chart. I was surprised to see two filters . I have already purchased the 1084 filter. My question is should I buy the 1410 and use it or will the 1084 be OK to use. Neither of my tractors will be doing any heavy use other than snow blowing. Thanks all for your help and have a great day.
Bob
Old 05-14-2018, 11:59 AM
Bob
I would return the filter you have if you can and get the correct one. I once used the wrong filter simply because it fit and it gave me trouble until I put the correct one on.
