Old 12-11-2018, 04:23 PM
cubs-n-bxrs's Avatar
You will need a 1" pipe tap with the about the first 3'8th inch of the leading edge cut off so it doesn't bottom out and some good tapping fluid. You will need to be extremely cautious while doing this as the area you will be chasing will be work hardened from all the heat cycles.
Old 12-11-2018, 05:13 PM
cooperino's Avatar
I thought he was indicating there were no threads lrft to chase...
Still no picture tho
Old 12-11-2018, 05:39 PM
twoton twoton is offline
Originally Posted by twoton View Post
Some of the blocks came with holes already drilled and taped for stud mounted exhaust flange. See post #184 in my thread ''What a rag' for a picture. If you have this on your block, Fab your own exhaust like the pullers do.
Blah, blah, blah...
Old 12-11-2018, 06:16 PM
Mudrig150's Avatar
Mudrig150 Mudrig150 is offline
Well it'll work, but I don't know how well it will.
Cubs: 1986 CCC 1912 Kawasaki swap, 1984 MTD 782D, 1985 CCC 1210
Other tractors: 69 Deere 3020, 69 Deere 140 H2, 64-ish Burns B60
Old 12-12-2018, 07:49 AM
Well Cooperino the existing threads could possibly be full of carbon giving the appearance of compromised threads. Unless you chase out the existing threads you have no idea what you are dealing with.
Old 12-12-2018, 08:07 AM
Mudrig150's Avatar
I know that the threads are messed up because why else would the wrong exhaust fit but the original elbow doesn't?
Like, they're there but they're sized up.
Old 12-12-2018, 08:47 AM
Ditto, I agree. Since we can't get any pictures, we don't know.
Old 12-12-2018, 09:40 AM
Mudrig150's Avatar
Appearence? There's literally no chunks of carbon on the threads. They're tapped for a bigger size pipe, that's all.
Old 12-12-2018, 11:22 AM
sorner's Avatar
sorner sorner is offline
How about an appearance of photographic evidence of what you're describing?
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
Old 12-12-2018, 11:51 AM
Blah, blah, blah...
Very good recommendation on the flange thingy. Halb, halb, halb...
Up to 534 and counting...
